Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Tech Essay(ish) Cossie ABS Fault diagnostics...
Old 09-12-2005, 07:12 PM
Damo V
Damo V's Avatar
Default Tech Essay(ish) Cossie ABS Fault diagnostics...
Mods, can you move this to the tech essay archives once everyone has seen it here
The cosworths run the Teves MKII ABS system, same as the Granada
The following are pictures I have taken from an Autodata book, detailing the ABS system on the Cossie, it shows everything except the "G" Meter (4WD) and fluid resevoir cap... I am still unsure if the 4WD Cossie has a pedal travel sensor too..
It hasnt helped me though it may help someone else ...
I have left the images full size, the links below the pics are direct to the images shown
http://img.photobucket.com/albums/06...s/DSC01274.jpg
http://img.photobucket.com/albums/06...s/DSC01275.jpg
http://img.photobucket.com/albums/06...s/DSC01276.jpg
http://img.photobucket.com/albums/06...s/DSC01277.jpg
http://img.photobucket.com/albums/06...s/DSC01278.jpg
http://img.photobucket.com/albums/06...s/DSC01279.jpg
http://img.photobucket.com/albums/06...s/DSC01280.jpg
http://img.photobucket.com/albums/06...s/DSC01281.jpg
http://img.photobucket.com/albums/06...s/DSC01282.jpg
http://img.photobucket.com/albums/06...s/DSC01283.jpg
http://img.photobucket.com/albums/06...s/DSC01284.jpg
http://img.photobucket.com/albums/06...s/DSC01285.jpg
http://img.photobucket.com/albums/06...s/DSC01286.jpg
http://img.photobucket.com/albums/06...s/DSC01287.jpg
http://img.photobucket.com/albums/06...s/DSC01288.jpg
http://img.photobucket.com/albums/06...s/DSC01289.jpg
http://img.photobucket.com/albums/06...s/DSC01290.jpg
http://img.photobucket.com/albums/06...s/DSC01291.jpg
http://img.photobucket.com/albums/06...s/DSC01292.jpg
http://img.photobucket.com/albums/06...s/DSC01293.jpg
http://img.photobucket.com/albums/06...s/DSC01294.jpg
Old 09-12-2005, 07:32 PM
DaveEscos
DaveEscos's Avatar
break the pictures up in to pages.. loads arent loading
Old 09-12-2005, 07:34 PM
Damo V
Damo V's Avatar
They have all loaded fine for me ... must be your net connection ...
besides Ive given the book back now lol
Old 09-12-2005, 07:47 PM
DaveEscos
DaveEscos's Avatar
Default Re: Tech Essay(ish) Cossie ABS Fault diagnostics...
no.. the last lot of pics, you havent added image tags
sort it out vennard !
Old 09-12-2005, 07:50 PM
Damo V
Damo V's Avatar
Best you re-read my post ... stop W4nking my friend
Old 09-12-2005, 07:53 PM
DaveEscos
DaveEscos's Avatar
May I refer you to the picture I posted on Tonys resto thread
Old 09-12-2005, 07:57 PM
Damo V
Damo V's Avatar
And may I confirm the fact I know exactly what he has just done
Old 09-12-2005, 08:54 PM
Neil S
Neil S's Avatar
I have the Ford Service Training manual for Teves. I'll gladly scan it in if there is enough interest
It centres on operation rather than fault-finding, but it has helped me out in the past
Neil.
Old 09-12-2005, 09:05 PM
boXXer
GASH!
boXXer's Avatar
just read the whole lot. Seems as though you are supposed to test it at the ECU plug rather than the sensors themselves. Is the sensor where the main ECU is in the car? Who does a Diagnostics tool for ECU's?
Mike
Old 10-12-2005, 04:13 PM
Damo V
Damo V's Avatar
boXXer The sensors end signals to the ecu (in the ECOs its in the boot) so checking at ECU helps eliminate dodgy wiring
You can use a EEC breakout box, though Im unsure where you may get one, I just used an ohmeter unplugging the loom from ecu
Neil S
Wouldnt mind seeing that mate.. Post it on this thread I reckon!!
Old 10-12-2005, 04:44 PM
boXXer
GASH!
boXXer's Avatar
ok cool, cheers for your help
Old 12-12-2005, 09:20 PM
xr4x4rs
xr4x4rs's Avatar
ok im confused
it says that to chek th ersistance connect an ohmeter across the ecu plug
now its saying pin 28 and 46 for a sensor but the ecu plug only has 35 pins
sorry to sound thick but this helpful but totally lost me at the same time?
Old 13-12-2005, 05:29 PM
Damo V
Damo V's Avatar
there are blank spaces on the ecu loom plug, if you look at the plug they are numbered, so even though there may only be 35 pins, they aren't all 1 through to 35... some are blank
Old 13-12-2005, 06:52 PM
xr4x4rs
xr4x4rs's Avatar
yes i that is true
but were the hell is pin 46 as stated above if the pins or blanks only go from 1 to 35
Old 14-12-2005, 04:20 PM
Damo V
Damo V's Avatar
i found it on mine...
there may only be 35 actual pins... but 50 or so slots for them
Old 14-12-2005, 04:36 PM
xr4x4rs
xr4x4rs's Avatar
nope there are only 35 actual slots and not all of them are filled with pins
how many rows do you have on you ecu plug i have 2
i can get a pic if you like
Old 14-12-2005, 04:55 PM
Damo V
Damo V's Avatar
I have 3 rows, you obviously dont run Teves MKII
Old 14-12-2005, 05:19 PM
xr4x4rs
xr4x4rs's Avatar
obviously not thought it wa sthe same throughout all sierras and escorts
looks the same lol
Old 03-01-2006, 05:55 PM
boXXer
GASH!
boXXer's Avatar
Right, gunna have a go at this tomorrow. So what settings does my multi-meter have to be on? As im SHITE at electronics.
Old 03-01-2006, 06:06 PM
ECU Monitor Enthusiast
I have a fully automated test tool for this ABS system.
This is a gadget I designed 5 years ago for a well known
automotive tools company who sold lots of them to the trade.
It tests EVERYTHING except the abs ECU itself.
It allows testing of the wheel sensors, valves and pump.
Also, you can jack a wheel off the ground, get someone else to
rotate it by hand then press then brake pedal, the wheel will stop,
then you can push a button and the wheel will release, testing the valve
block and abs pump pressures by true operation.
This is all done by removing the ABS ecu, replacing it with the
test one and the unit has a display and keyboard so you can
perform one of 50 tests to check the system quickly.
If you get stuck, I can let you borrow it for a few days.
May even sell it now as I have an Escort Cos and it doesnt do that system.
Old 03-01-2006, 06:19 PM
boXXer
GASH!
boXXer's Avatar
Sounds like a wicked tool mate. Wish i was as clever as that! lol.
Old 03-01-2006, 06:39 PM
rsnissan
rsnissan's Avatar
excellent that confirms what i was saying about how to test the sensors a while back then
As Damo says testing at the ecu multiplug will yield the same results but uses the wiring from the sensor to the ecu instead of just checking directly at the sensor (but it good to check this part of the wiring also )
Old 03-01-2006, 06:42 PM
boXXer
GASH!
boXXer's Avatar
so should i test it at the sensor plug, and the ecu plug? What settings does the multimeter have to be on? and where are the sensor plugs on the 3dr?
Cheers mate
Mike
Old 03-01-2006, 06:45 PM
Damo V
Damo V's Avatar
Cheers mate
Mike
Just ECU is easier IMO as you can maintain a constant speed easily and see how they compare ie 10mph 20 mph etc
Voltage (V) now I think its AC..??
Inner wings and under rear seat ??
Also you need to check for resistance/continuity IIRC
Old 03-01-2006, 06:49 PM
Damo V
Damo V's Avatar
Ive just looked at the pics again... its all up there, page 133
Make sure you remove sensors and clean all the grooves on driveshafts etc then repack with cv grease
xr4x4rs
xr4x4rs's Avatar
i had to test mine at the sensor only way i got a reading was when it was set to milli volts on the meter
and in the end i gave up as i couldnt work out which one needed a seensor
so changed the two fronts and was still the same
so just cleaned the earths up on the sensors and sanded the hub down to get rid of surface rust
put it all back together and job done abs working again and no probs since
Old 03-01-2006, 07:00 PM
boXXer
GASH!
boXXer's Avatar
So are you saying that i should test it whilst driving along?
Old 03-01-2006, 07:03 PM
rsnissan
rsnissan's Avatar
i just checked my sensors one by one (disconnected them and checked the voltage)
As per Damos post
you are looking for around 0.2 volts at a wheel speed of 60 rpm.
I of course didnt know what the voltage was supposed to be however all i needed to know was that the sensor WAS giving a reading of some sort that varied with wheel speed (obviously increasing with wheel speed)
if i had know the pin outs i would have checked at the ECU end but it makes no odds really if just testing the sensor.
you want the Multimeter set to voltage and anything thats capable of reading around the range described in the pic above (0.2v)
My particular multimeter was set to 200mv - 2v but others may be different!
the sensors plugs below the rear bench on the 3dr (maybe others) and come through the chassis rail at the front IIRC.
i found one of mine wasnt earthing properly and just needed a clean up as well as the hub needing a quick going over with some sand paper when the sensor bolts in.
Damo V
Damo V's Avatar
I did, much easier than fannying about trying to read a voltmeter with a quick spin of a wheel... just find an empty straight quiet road ... I used an Ind est on a sunday
Old 03-01-2006, 07:05 PM
rsnissan
rsnissan's Avatar
ahh beaten by the man himself but yep page 133 is all you need to know for the sensor check
Old 28-03-2006, 10:19 AM
Dave Henshall
Dave Henshall's Avatar
good find , well done that man
Old 25-06-2006, 07:16 PM
Jay,
Sponsor
Jay,'s Avatar
ive got a autodata breakdown of pinouts and how to check the sensors itsabout 4 pages can copy them for anyone and post if wanted
Old 25-06-2006, 07:48 PM
frog
0-60 in 17 seconds (eek)
frog's Avatar
Yes please sir
Old 26-06-2006, 09:00 AM
boXXer
GASH!
boXXer's Avatar
mines still broke. tried to get the tool off of secs, but to no avail. bloody fords.
tankybaby66
06-02-2016 02:24 PM
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Quick Reply: Tech Essay(ish) Cossie ABS Fault diagnostics...
