Prime example of why....
Old 25-10-2008, 04:15 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Default Prime example of why....
....Dyno's get a bad name.
Whilst looking for some info, I came across these graphs.
They supposedly show an R8 (Milltek) before modification and after fitting their cat-back exhaust.
Before.....
After.....
For those that don't know, if you look at the first graph, in the data at the bottom, you'll see 2 values. 'AT' and 'IT'. The 'AT' value is ambient air temp. This of course should be something like the current temperature. The 'IT' value is intake air temp. We look for a maximum deviation of 8°c between these 2 values. There's 28°c difference on this graph. The dyno will be applying a massive compensation as a result of this.
Also, that run was carried out in 'Shoot_8' mode, which is for 8-cylinder engines.
Now look at the second graph. Again, check the AT and IT values. AFPMSL. 76°c. That is just plainly insane. We'd use those graphs for nothing more than toilet paper. However, just as significant is the fact that the second run was carried out in an entirely different mode 'Shoot44', which is for 4-wheel-drive cars. So, with both plots on the one graph, comparison is just ridiculous and would make their work look better than it actually is.
Incidentally, the car only reached just over 80mph in the first graph. What's that all about?? LOL.
Old 25-10-2008, 04:22 PM
roro22
roro22's Avatar
Is this done on purpose to distort the figures?
Old 25-10-2008, 04:29 PM
Psycho Warren
Carbon Crazy
Psycho Warren's Avatar
Just goes to prove a dyno is only as good as the numpty operating it!!!
Old 25-10-2008, 04:32 PM
Christian and Beccy
#1 in Spelling Club
Well, tell me how on earth they measured 87°c at the temperature probe that is supposed to measure intake temp?
Surely that's about the same temperature as a fresh cup of coffee?? or between the fins of the radiator?
Personally, I think the fact that they plotted against 'Speed' and not 'RPM' is because they didn't actually measure RPM, and thats not the best way to do things either.
Old 25-10-2008, 04:33 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
How do you take the inlet temp? Isn't a probe put into the filter? I always thought the best inlet temp would be taken from either inlet manifold or boost pipe, but how do you go about that without having to mod everycar you RR.
Old 25-10-2008, 04:37 PM
Christian and Beccy
#1 in Spelling Club
It's actually adequate to have the sensor in the 'vicinity' of the Air Intake. In reality, the air that is drawn in doesn't spend long enough into the engine bay to be too affected by engine-bay temps, especially with the bonnet up.
Old 25-10-2008, 04:49 PM
ECU Monitor Enthusiast
PMSL.... Something is definitely not right there
Wont say what otherwise this thread will only end up with me and chip arguing
Old 25-10-2008, 05:07 PM
Ginge !
just finding my feet
Ginge !'s Avatar
and in 3rd gear too
Old 25-10-2008, 05:33 PM
Chris69
Chris69's Avatar
interesting you just started this as i've been somewhere else where the dyno dynamis rr seemed to be playing up.
i had a RR done today and for some reason the RR kept throwing up some weird results- my 2litre focus mad 171bhp for example at one point
heres one he did later on after a reboot of the system- do the settings look ok? ignore the map i think i'm gonna chuck me bluefin in the bin
Old 25-10-2008, 06:21 PM
M-Tech... LOL, thats in my town and I never new it was there
Old 25-10-2008, 06:33 PM
Chris69
Chris69's Avatar
the're very new mate and hes only recently got this RR thats why i put the post up to try and get some feedback as i'm sure you'll appreciate he doesn't want a bad rep for non accurate results after spending so much money on wot is regarded as the best RR out there atm.
Old 25-10-2008, 06:35 PM
Are you local Chris...Dilton ???
I live in westbury
Old 25-10-2008, 06:39 PM
Chris69
Chris69's Avatar
relatively, am in bristol mate- have a fair few mates in the trowbridge area hence knowing about this new place.
Old 25-10-2008, 06:43 PM
Ahh ok.. Must pop down there, didnt know they existed. !!!
I am in the ECU business (not so much road cars now) lol
Old 25-10-2008, 06:51 PM
Chris69
Chris69's Avatar
yeah give them a bell mate there just starting out like i said but its nice to have another option and he is very reasonable while trying to sort his workshop out.
sorry for topic hijack i'll shutup now
Old 25-10-2008, 06:53 PM
Mark Shead
Mark Shead's Avatar
This is why I think DD should get ride of the inlet temp correction and only have room temp correction.
Mark
Old 25-10-2008, 07:58 PM
Christian and Beccy
#1 in Spelling Club
Originally Posted by Ginge !
and in 3rd gear too
At least they got one thing right.
Mark
It is WIDE open to abuse, but at least in Shootout mode its obvious for all to see.
As long as the differential is in the range of 0-8°c, it's acceptable. Thats the general rule of thumb. It is right for there to be a correction because the temperature away from the cell, where the weather station is, may not be the same as that in the direct vicinity of where the air is being drawn into the intake, although they won't be too much different.
Old 25-10-2008, 08:21 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Before.....
After.....
I will bring this to Mikes attention as they need their shootout status looking at!!
Old 25-10-2008, 08:27 PM
Christian and Beccy
#1 in Spelling Club
You'd probably find that the second run made less power than the first when you take the temperature compensation out. I can't imagine that Audi got the exhaust on the R8 that wrong.
If I had bought one, I'd be talking to trading standards.
Old 26-10-2008, 11:28 AM
pee vee
pee vee's Avatar
chris, have you still got the graph of when it said your focus made 172? LOL
as after they messed with it. Everyone was getting low readings IMO.. cars making 20-40 bhp less than standard
regardless of if the car was standard or modified lol
Old 26-10-2008, 11:39 AM
Chris69
Chris69's Avatar
he didn't print it off in the end but i'll call him to get him to e-mail me the file on monday- jay/burni has got the print off where his pretty much standard 16v golf gti made 167 on the rollers
tbh i think most of the results where pretty far out be it high or low thats why i put the graph up
Jay said if you put his 123bhp and 167bhp graph next to each other the power an torque curves are quite different which is worrying seeing as its the same car!
Old 26-10-2008, 11:48 AM
pee vee
pee vee's Avatar
can you get him to put them up lol
Old 26-10-2008, 11:58 AM
Steven_RW
Steven_RW's Avatar
I buy an exhaust on a sports NA car just for the noise - zero expected gain. Only hidden benefit on the M3 was the sports version is considerably lighter.
RW
Old 26-10-2008, 04:55 PM
Chris69
Chris69's Avatar
he may do later phil, hes busy 2day so maybe later.
Old 26-10-2008, 06:17 PM
dojj
Resident Wrestling Legend
dojj's Avatar
now you point it out, it's obvious
but i would have thought they took thereadings in 4th gear rather than 3rd to give you less transmissio losses to contend with
i suppose it's all to do with giving the figures people expect rather than the figures they need to see eh?
Old 30-10-2008, 09:31 PM
pee vee
pee vee's Avatar
is there anyway of telling from them graphs if thats ATW power, or flywheel power?
Old 30-10-2008, 09:33 PM
GaryEvo
GaryEvo's Avatar
on axis hp is at the wheels,s-hp is at fly
Old 30-10-2008, 10:17 PM
RWD Pete
RWD Pete's Avatar
cheeky bastards, its hard to belive a cat back system on a finely tuned modern engine would make hardly any difference
Old 30-10-2008, 10:43 PM
Alg1k
Alg1k's Avatar
I had the same trouble
My rear wheel drive car was done in shoot44 mode
Which i knew nothing about .
AS SAID Only as good as the operator
Old 30-10-2008, 11:16 PM
Šhatter Box
Šhatter Box's Avatar
i would of thought when you get sold the dyno you wpuld of got shown on how to use it
Old 31-10-2008, 08:39 AM
dojj
dojj's Avatar
you must be thinking about when posh blokes who don't know how to drive buy ferraris and lambos and then need to be taought how to drive them in a straight line and in traffic
people who buy a set of rollers shouldn't really need to be shown how to use them as they should be intelligent enough to figure out the instructions
Old 31-10-2008, 09:26 AM
Christian and Beccy
#1 in Spelling Club
Dojj, thats not entirely true. Dyno Dynamics do show you how to use the Dyno, but NOBODY is born with the knowledge and only time and usage of the Dyno can teach you how to overcome obstacles.
We've been using Dyno's for quite a few years now (infact back to about 2001) and have used more than one system, so have diverse experience. We also know that giving out 'fudged' figures is a really bad idea, because it will eventually come back and bite you on the arse and we are not into that.
The truth is that we don't use ours [i]exactly[i/] as we were taught, but the only changes we've made are where we have discovered a better way and a way that gives more consistent figures.
Old 31-10-2008, 09:30 AM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
and in 3rd gear too
thats what it should be
Old 31-10-2008, 09:45 AM
dojj
dojj's Avatar
c&b
so does this mean that not only should the DYNO be TUV approved, the opperator ALSO needs to be TUV approved then?
like an mot bloke?
Old 31-10-2008, 10:11 AM
Christian and Beccy
#1 in Spelling Club
AFPMSL.
Old 31-10-2008, 10:22 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
c&b
like an mot bloke?
The question you should really be asking yourself is, "Is the dyno operator of sufficient competence" .
You wouldn't go to any old person to have major surgery or even your engine built. Same should be about dynos, you should only use someone who knows what the fuck they are doing .
Old 31-10-2008, 10:57 AM
dojj
dojj's Avatar
but having a bit of paper in a glass display cabinet on the wall should be able to give yuothe reassurances that those peole on the list can do what they do
although i'm sure that those unscupolous chracheters might fudge their accreditations as much as their figures
at least we now know what to look out for when we see a graph so for pointing them things out everyone
Old 31-10-2008, 11:00 AM
D19 STE
D19 STE's Avatar
I had my old Si done on a Dyno Dynamics RR a few years ago now and I didnt have a clue what all those figures meant on the bottom just noticed they had my tyre pressure at 40psi if that what it means
Old 31-10-2008, 11:03 AM
Christian and Beccy
#1 in Spelling Club
Dyno Dynamics actually sugggest 50psi in the tyres!
That run was clearly in 4th gear too, which is wrong for this system.
Old 31-10-2008, 11:06 AM
D19 STE
D19 STE's Avatar
Just noticed that, why is 3rd gear better than 4th on this system and would you up your PSi to 50 or is that just for the computer?
Quick Reply: Prime example of why....
