Bit of an engine problem! Blocks apart
Old 31-12-2013, 11:13 PM
  #81
Jay,
Sponsor
Jay,'s Avatar
Originally Posted by ajamesc
Head looks ok 4 bent valves the piston has touched the head but not bad no damage in the chamber and the valve seats are not marked
[URL=http://s737.photobucket.com/user/ajamesc8392/media/image_zps33bc98cb.jpg.html]
Are you using this head mate as it might be a bad pic but it looks like its been ported by a blind man
Old 31-12-2013, 11:18 PM
  #82
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Lol must be my shit iphone camera un less you have drank too much as it's nye!
But yes mate mark has the head it's been checked and re built so ready to go back on at some stage when I've sorted all the bits I need. Have my block now so I'll drop that off soon. The head was done by who ever mark uses so I'm guessing they know what there doing
Old 31-12-2013, 11:21 PM
  #83
Jay,
Sponsor
Jay,'s Avatar
I only say as the left port looks round and even and the right port looks smaller and more like a egg shape
Lee2909 (25-02-2022)
Old 31-12-2013, 11:24 PM
  #84
ajamesc
ajamesc's Avatar
Yeah I know what you mean bud it will be shadows it's hard as fuck to take pics of anything shiny in are workshop the lights are too bright always have the same problem sending pics to Daf technical they turn out odd looking
Old 01-01-2014, 08:15 AM
  #85
Mark Shead
Mark Shead's Avatar
No his guide dog was doing the workand it's clearly his shadow you can see
Mark
Old 03-04-2014, 05:57 PM
  #86
ajamesc
ajamesc's Avatar
Slow progress with this one lol but I'm still hoping to have my engine in late July to August with the clutch breather system cooling and inlet all done! That will just leave the turbo exhaust manifold and system to do ready to run in for mapping early next year when it's dry! Well that's the plan lol
Heads is done block is dropped off and I've payed for the pistons and rods to be ordered
Old 03-04-2014, 09:19 PM
  #87
DAN400
DAN400's Avatar
did u ever strip the bottom end to see what happened ?
Old 03-04-2014, 09:21 PM
  #88
ajamesc
ajamesc's Avatar
Not yet lol haven't had time plus I can't be arsed in the shit weather but I will get on it soon
Old 17-05-2014, 04:45 PM
  #89
ajamesc
ajamesc's Avatar
Finally pulled the block out today so I'll strip it on Monday and see what went wrong lol I'm guessing piston or rod broke. Be paying for the work on my new block on the 25th ish so will be one step closer to putting the engine back in
Old 19-05-2014, 06:03 PM
  #90
ajamesc
ajamesc's Avatar
Well it's apart and it looks like the bottom of the piston broke
Sumps not too bad so I'll get Andy Roberson race cars to fix that
Front pulley was a cunt to get off lol good job I didnt need to do the cam belt
Other 3 rods and pistons are ok so my mates going to put the pistons to use in his after buying a 4th
Also one of the crank counter weights is scored I'll not be using the crank in mine but I'll send it to the mashine shop we use at work to be checked for cracks and balance and see if the score can be removed if so I'll put it up for sale after
Old 19-05-2014, 06:22 PM
  #91
Mark Shead
Mark Shead's Avatar
When a rod bends and let's go it can break and smash the pistons to its a diff one to work out what went first.
Mark
Old 19-05-2014, 06:24 PM
  #92
Mark Shead
Mark Shead's Avatar
Didn't see Picts before I posted I would guess it was the pin breaking first.
Mark
  #93
What a mess you have made of that piston lol.
Old 19-05-2014, 06:28 PM
  #94
scoooby slayer
scoooby slayer's Avatar
jesus look at that rod
Old 19-05-2014, 06:30 PM
  #95
ajamesc
ajamesc's Avatar
To me as the small end hole is still there just beaten flat lol it looked like the piston broke up and the gudgeon then fell out and the rod beat the bottom of the piston and smashed the block the pin is 3/4 in tact so that didn't brake but it's all guess work really lol
But iver way I did a proper job of it lol
Old 13-06-2014, 02:41 PM
  #96
ajamesc
ajamesc's Avatar
Took my pedal box out today and modded ready for a hydraulic clutch set up
Old 13-06-2014, 06:15 PM
  #97
Cool. Is it easy to mod.
Old 13-06-2014, 06:20 PM
  #98
ajamesc
ajamesc's Avatar
Doing that was Glenn! Just a matter of cutting off the pedal stop and drilling the pedal with an 8mm hole for a clevis pin that will take the rose joint which will screw to the master cylinder push rod.
I'm going to use a wilwood .70 master and e30 bmw slave after reading into it on here. All in with lines and remote bottle should be under Ł100 but I'll have to get my bell housing modded as are alloy welder at work is shit lol
Old 13-06-2014, 06:24 PM
  #99
Cant beat cheap mods matey.
Old 13-06-2014, 06:43 PM
  #100
natehall
natehall's Avatar
How far down the clutch pedal do you drill the hole for the pin?
Old 13-06-2014, 06:49 PM
  #101
ajamesc
ajamesc's Avatar
Taken from a resto thread on here pointed out by the guy who's thread it is and jay. 50mm down from the center of the pedal bush hole. Also before I mount the the master I'll make sure it's sitting nice before drilling the bulk head for the master.
Old 13-06-2014, 06:59 PM
  #102
bigchez
bigchez's Avatar
well if a job's worth doing and all that!!!
Old 13-06-2014, 07:05 PM
  #103
ajamesc
ajamesc's Avatar
I'm sick of the car it's a money pit lol but it's my hobby and it dose still make me smile purely because of how fast it was. I'm going through the car front to back so once it's next mot'ed I'll not have to spend any more money on it. So as well as doing the engine I'll also be putting adjustable front arms on it a 6 degree beam and supra diff
Lucky enough every thing else on the car is already done like box brakes and things like that
Old 13-06-2014, 09:45 PM
  #104
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Do you regret that ride in mine all those years ago Andy . Racing & beating that R1 started you on all this money pit shite .
Old 13-06-2014, 09:48 PM
  #105
ajamesc
ajamesc's Avatar
I do hold you responsible rod I was perfectly happy with cav Sri 130's and Reno 21 turbos
Old 29-07-2014, 02:00 PM
  #106
ajamesc
ajamesc's Avatar
Very small up date lol things are going slow but should speed up end of October / November time!
I finished modding my pedal box ready to re fit and now have a small rose joint fitted to it and I have a 0.70 master cylinder
Also got my breather system ready to mount wear my battery lives.
Old 29-07-2014, 02:04 PM
  #107
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I must fit the engine in the 4i lol
Hope your back on the road soon
Steve
Old 29-07-2014, 02:08 PM
  #108
ajamesc
ajamesc's Avatar
Steve
Will be a long road for me mate but I'm sure it will be done by summer ish next year it's an expensive game lol.
Old 29-07-2014, 02:26 PM
  #109
cossie4i+
TT T38 Power
cossie4i+'s Avatar
The 4i would of been on the road ages ago if I didn't have the 3dr.
Family life, bills etc come first before the 4i is back on the road, almost saved enough now
Steve
Old 30-07-2014, 01:27 PM
  #110
ajamesc
ajamesc's Avatar
Steve
Be worth it when done!
Old 30-07-2014, 03:08 PM
  #111
I was expecting the engine to be back in and running lol.
Old 30-07-2014, 03:12 PM
  #112
ajamesc
ajamesc's Avatar
Ha ha I wish I've a lot to do. I'm chipping away at the little jobs at the mo like clutch set up and mounting my breather / moving battery to boot.
Engine wise I think I'm just waiting on the pistons so the liners can be fitted. So shouldn't depending how long they take be too long till that can start to go back togther.
Old 30-07-2014, 03:14 PM
  #113
Well get a move on then lol. That breather looks a canny bit of kit.
Old 30-07-2014, 03:16 PM
  #114
ajamesc
ajamesc's Avatar
Yeah should do the trick lol what with exhaust manifold turbo and ful exhaust system I'm most likely looking at summer ish next year lol.
Old 30-07-2014, 03:44 PM
  #115
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Im looking forward to the day it is
Just need to save harder to pay Tone the Moans mapping bill
Steve
Old 02-08-2014, 12:08 PM
  #116
ajamesc
ajamesc's Avatar
Had a nightmare trying to figure out wear to mount my clutch master on the bulk head as it's such a funny shape! All the others I've seen seem to have the rose joint in the middle of the pedal. Mounted like that I could not mount the master in a nice place and get a nice smooth straight push rod travel. So I got pissed off and did it my own way lol mounting the rose joint to the side on the pedal. I also re enforced the pedal by welding a washer to iver side wear the bolt go's through it.
Mounted my breather to the battery tray as well. Not the greatest of up dates lol but the little jobs are just as important
Old 21-09-2014, 03:33 PM
  #117
ajamesc
ajamesc's Avatar
Been about a year since I broke the old girl now! Progress has been a little slow but the list of parts ive been gathering has been rather expensive! Im not cutting any corners with this I want a very very fast car when its back. All the major engine bits are payed for now and iver with mark or sortly to turn up I just need to drop off a new cranksharft which I will in the next week or so. Also ill be using mechanical lifters but im told its a simple change so in the next few months building the engine should start ready to get it in the car early ish next year. Im thinking ill take my rear beam and gripper diff out as well and get the beam modded to 6 degree and fit a supra diff as I don't think the hewland 7.5 inch cwp will be up to the job!
Old 11-10-2014, 05:23 PM
  #118
ajamesc
ajamesc's Avatar
Picked my sump up from my mate today as he has repaired the two holes in it! Also fitted a boss for my oil temp gauge and the breather return line. He also made a gate style baffle.
Old 11-10-2014, 05:29 PM
  #119
scoooby slayer
I had a Renault 21 turbo and I thought it was the nuts til I went for a ride in a stage 3 saph I soon realised the Renault was pants lol
Old 11-10-2014, 05:32 PM
  #120
ajamesc
ajamesc's Avatar
Same as lol I thought my 21 was really fast till I went in rods with about 400bhp
Quick Reply: Bit of an engine problem! Blocks apart
