P100 Cosworth build 4x4 (Update 17/4/14!!!)
#43
Quick question is a 2wd diff the same as a 4x4 diff only reason i ask back in April 2004 Performance Ford featured a blue 2wd P100 but when i dug it out and read the feature he said he used a 4x4 set up on the rear so if it become a handful being 2wd he could convert it to 4x4 easier .Sure was a nice truck Saff side skirts fitted to he says you need 2 sets of side skirts cause of the length .Was on escos rims any one else remember it
#44
the 2wd is 7.5" and 4x4 is 7" but i think the 4x4 ratio has more pulling power at lower end due to the ratio being diffrent .
and yep you need two sets i have mines ready to go on once i get it resprayed
#45
Pick-up P100 Power!
You can use all the 4x4 rear end. Better arb, vented discs etc. You need to change the box, front hubs, calipers, sump and cross member. Mine is all.4x4 rear, loom, engine harness, abs (2wd abs Ecu), water pump, inlet and exhaust manifold etc but 2wd block and head. If you have a pinto p100 you can use that cross member and tca's but you might want to change the front arb.
#46
Here is a forum post I have read that mention the changes: (I'm not a mechanic / MOT tester, just posting something I read)
http://www.edition38.com/forums/inde...owtopic=381364
TL;DR
Your car WILL need an IVA if you:
C notch the chassis legs for driveshaft clearance
Raise the strut tops
Modify the floor or bulkhead
Chop the roof off/convert to a pickup
Cut the outer arch lip for tyre clearance/to fit a wide arch kit, as this is classed as a structural area
Modify any part of the monocoque
TL;DR
#47
Shark conversions
interesting read that mate.i didnt no anything sbout this mot change very helpfull link.
there must be alot of modified cars out there needing a iva test. if its been modified properly there should be no problem if flagged just a hole in the pocket
#48
Pick-up P100 Power!
TL;DR
TL;DR
#49
#51
Pick-up P100 Power!
Anti roll bar. Your need to lengthen a 2wd cossie prop but the from the box back will all work fine.
The front p100 arb is 2mm smaller than that from a 2wd cossie so its up to you if you want to change it. Your need to mod the brackets or revnut for either 4x4 or 2wd front arb. Im told you can buy poly bushes to work with either or but im yet to find them
#52
#53
TL;DR
TL;DR
#57
Just a little up date ive been stripping the truck in the evenings coming on well .Going for the easter weekend to strip the Saff .Ill get rst to put the pics up as i aint got a clue .Just one bit of advice any tips on getting the torx bolts out for the tub im soaking them in oil but you can feel the threads are full of crap 6 of them to undo .
#58
look at it this way we all see modded cars at shows and you think to yourself how dose that pass an mot ? and if you think that so will the police/vosa so its all about not being silly with the mods and make sure everyone is done 100% correct at the end of the day your the one sitting in it
#60
Pick-up P100 Power!
#61
#62
#63
#64
Cheers buds im going to carry on building it by the end of this week i should have truck stripped as im only doing an hour or so in the evenings cause ive been working weekends .I just keep chipping away at it and thinking it will be well worth it in the end
#66
The MOT changes are difficult to interpret though
#68
#73
UNAUTHORISED DEVELOPMENTS
I reshelled my xr4x4 into a 4i, i fitted the complete 4x4 front end, no chassis rail notches, and fitted a type 9 2wd box. I just left the front diff, driveshafts etc. in situ but never ran it 4wd. At least if you do it that way, you can make it 4wd at a later date.
#77
LOL we have go a garage but the mk2 s in there but thats going to another store so once we start fitting truck up ill put it in the garage .But i now what your saying about hardcore once your into it you dont think about the weather just wrap up and get waterproofs on
