Fiesta Mk3 project
Old 04-09-2011, 04:30 PM
sparky MK3
sparky MK3's Avatar
Default Fiesta Mk3 project
hey guys, Im just starting out modding my 1.1 mk3 fiesta but cant really find many parts for it, im considering an engine swap but havent done it before so dont want to put anything too different in it, also looking for any other worthwhile performance mods? il be greatful for any ideas or advice
Old 04-09-2011, 04:32 PM
gouch1
gouch1's Avatar
get a rottern 2i and youll have loads of good stuff
Old 04-09-2011, 04:46 PM
sparky MK3
sparky MK3's Avatar
would it take much work to put an xr2 engine into it?
Old 04-09-2011, 04:59 PM
Adam31
Waiting on my fast ford..
Adam31's Avatar
As above, get a bargain xr2i from ebay, better with the zetec one but depends what is out there. Sit the 2 cars side by side and swap over the parts that you want, engine, box and wiring, brakes and possibly the suspension. Easiest way to get the extra power straight out the box.
If you can find a rotten RST with a good engine would be even better.
Old 04-09-2011, 05:09 PM
sparky MK3
sparky MK3's Avatar
ok thanks guys il get on it right away
Old 04-09-2011, 05:19 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
As said already really, RST would be better, but an xr2i would be a heap more fun than the 1.1, if you've got the money after then look at the usual mods, exhaust system, manifold, cone filter/panel filter, a lumpy cam and map/chip, not sure whether the ecu was a chip job or if it can be remapped instead.
Some lower and stiffer springs with some half decent tyres will see you through the corners, even better if you strip the back end out if you don't mind the extra noise
Prickly_buzz
07-12-2017 09:52 PM
DHMC
Ford Fiesta
30-09-2015 07:15 PM
liamT74
23-09-2015 10:24 PM
fordfiestamk3
11-09-2015 12:52 PM
Brian
11-09-2015 08:06 AM
Quick Reply: Fiesta Mk3 project
