XR 4X4 Injection system Help
Old 28-08-2011, 07:23 AM
thebarbs
thebarbs's Avatar
Default XR 4X4 Injection system Help
Hi all,
I have just rescued a couple of 1988 XR 4X4s, one of which was a recent runner?
The other has been sat for several years.
I have tried to get the recent runner going but not having much luck. I have the Haynes manual for guidance and found the fuel pump relay was missing and fitted a generic relay, which has got the fuel pump running. It would also seem the Injector relay is missing?
The engine turns over, I have a spark and it seems to try, but only with "start pilot"
I think the fault is in the injection system, but need to know where to start looking first.
I have done the usual things before trying to start the car, fresh fuel, oil and checked the water system, I also ensured the camshafts were well oiled before starting.
Any help and advice would be appreciated.
Cheers, thebarbs
Old 28-08-2011, 09:52 AM
COLEYST200
COLEYST200's Avatar
Wecome to the site and all the best with the cars one of the old tricks iv done in the past is pull a plug out and put a bit of fuel in the bore and put the plug back in and hit the key some times that one fire up can sort it but i bet you have tryed this
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Iain Mac
30-09-2015 09:39 PM
Quick Reply: XR 4X4 Injection system Help
