3dr
02-09-2014, 06:43 PM
3-door moonstone
Most of the bottom end done now new clutch cable with heat sleeving, started on the inlet trumpet section
Inlets going to be a week or so at the polishers so will make a start on the head
04-09-2014, 05:29 PM
3-door moonstone
Made a start on the head tonight manifolds on and thermostat housing
Ordered new cap rotor and plugs and a new crank sensor the wires where frayed
05-09-2014, 06:49 PM
3-door moonstone
Got little more done tonight turbo bolted on
06-09-2014, 04:08 PM
3-door moonstone
Got the head refitted today
Gave the cam cover a polish before refitting
Refitted
07-09-2014, 03:04 PM
The cam cover looks really bling.
07-09-2014, 05:04 PM
3-door moonstone
Had a few setbacks today first of all the crank sensor wire fell off as I removed it luckily I had bought a new one anyway
Then fitting the cambelt the stud for the tensioner stripped it's thread, not a good morning I retapped it nut wasn't happy with it so got a helicoil kit and sorted that out. Alls good now belt on and timed up
Need to get a gasket for the turbo oil return pipe then that can go back on, need to get the plenum back from the polishers then can get that sorted out
07-09-2014, 07:09 PM
An amazing read Simon ,No stone left unturned on this one mate well done it's an awesome car that just keeps getting better
07-09-2014, 07:26 PM
3-door moonstone
Quote:
Originally Posted by
pauloopnorth
Cheers bud
07-09-2014, 08:23 PM
Getting there now mate.
07-09-2014, 09:12 PM
3-door moonstone
mk2cossy
Nearly there bud
09-09-2014, 06:17 PM
3-door moonstone
Got the intercooler back in today
And polished the radiator ready to go back in
13-09-2014, 05:35 PM
3-door moonstone
Finally got the inlet back from the polishers think they've done ok
Made sure all the threads are good just to be safe
Then mocked it all up to see how it fits
Really close at the back to the brake pipes out of the abs block but might just get away with it, just the pipe work to sort out then.
14-09-2014, 11:18 AM
Nice bit of kit that matey.
14-09-2014, 12:08 PM
Live long and prosper!!
Shit me... where is my sunglasses
U will need shares in metal polish Si.
Paul
14-09-2014, 01:36 PM
3-door moonstone
costina
Paul
Good job I don't mind cleaning it ha ha
14-09-2014, 01:37 PM
3-door moonstone
Cheers bud hopefully should squeeze a few more bhp out of it, looks the part too
14-09-2014, 04:05 PM
16-09-2014, 06:26 PM
3-door moonstone
Started on the radiator fan surround today the brackets where rusty and some broke
So found someone who makes new ones in stainless, just a matter of drilling the old pot rivets out and new ones on and new pot rivets
Not too bad certainly better than the old ones
16-09-2014, 08:39 PM
Si do you have a link for those brackets. saves a lot of messing about
16-09-2014, 09:09 PM
3-door moonstone
171461602487 item number fela
16-09-2014, 09:10 PM
costina
i need some as well
16-09-2014, 10:13 PM
sit boo boo sit
Looking sweet cheif
good find on the brackets...
17-09-2014, 05:50 PM
3-door moonstone
Cragrat
Looking sweet cheif
There not too bad fela should do the job
21-09-2014, 08:37 PM
3-door moonstone
Started to sort the pipework out, the vac pipes have been rerouted
And have to sort the cooler pipe out aswell
26-09-2014, 10:47 AM
3-door moonstone
Now I've run the loom under the inlet the iscv was a bit short so rather that cut it made an extension piece with the proper plugs on
Decided I wanted to keep the throttle cable at the front so got a bracket but that's caused new problems too close to powersteering pipe now
Got the oil breather fitted with the pipes routed a bit better now
27-09-2014, 05:41 PM
3-door moonstone
Got a bit more done today sorted power steering pipe out and got all the water plumbed in, just the belt cover and exhaust to sort out
27-09-2014, 10:20 PM
That engine looks smart as fook.
28-09-2014, 07:37 AM
that engine looks amazing
28-09-2014, 10:13 AM
3-door moonstone
DavebST170
Cheers fela gonna be a bugger to keep clean ha ha
3-door moonstone
Cheers bud it's getting there now
16-10-2014, 05:07 PM
3-door moonstone
Haven't done much for a while but got the strut brace and heat shield back on tonight
16-10-2014, 08:45 PM
17-10-2014, 03:00 PM
3-door moonstone
Cheers fela nearly there now
17-10-2014, 11:49 PM
It's looking very nice mate
18-10-2014, 08:39 AM
Have you had it running yet.
18-10-2014, 08:44 AM
3-door moonstone
Not yet bud hopefully Sunday will be firing it up
19-10-2014, 05:38 PM
3-door moonstone
Finally got it running today started first turn of the key caught me by suprise
Ran it up all looks ok the the battery light came on, after a bit of searching and head scratching traced it to the alternator wires badly perished and hanging out of the plug
Peeled it back to find this
So cutting all that out and replacing it and braiding it then wrapping in heat proof sleeping, that's my job for tomorrow
The main cable seems too big to solder any one done this before
19-10-2014, 06:34 PM
Just run a new cable back to the battery
19-10-2014, 07:15 PM
3-door moonstone
Does it go straight to the battery, not traced it back yet?
20-10-2014, 05:05 PM
3-door moonstone
Sorted the wires to the alternator but the light on the dash is still on and only putting 12.2volts in battery when running
Put a mates old alternator on and lights gone off but only 12.6volts
So think it's defo time for a new alternator
