Cossie YB into my race car project*update RR print out!* 02/4/11
Old 12-12-2010, 06:50 PM
The Youth.
The Youth.'s Avatar
Default Cossie YB into my race car project*update RR print out!* 02/4/11
Should have started this thread earlier but I will back date it from the start to where I am now
After using the car this year in the northern saloons it became obvious to me that my car just wasn't fast enough (any racer will tell you that no matter how fast there car is! lol)
so I decided over this winter to collect everything I need to put a Cossie YB turbo motor in to give it some extra go..had myself a huge shopping list of parts needed
picked the engine up, seems ok so far, going to keep the late style power steering alternator set up as I have the pipes for this already,
it came with a 2wd exhaust manifold which I have removed as I'm not using it so I took the opportunity to try my 4x4 manifold on with the t34 I will be using.
decided to take the crank out and polish or regrind as required with new big and main bearings
steve
Old 12-12-2010, 07:11 PM
Cragrat
sit boo boo sit
Cragrat's Avatar
steve
good luck steve,i thought the 2wd ex manifold was better flowing though?
what spec you going after old bean
Old 12-12-2010, 07:12 PM
The Youth.
The Youth.'s Avatar
when stripping the engine I found a few faults such as the badly fitted inlet manifold gasket!! it also had a sump gasket fitted
got myself a paddle clutch
Fitted a quicksift knuckle to the gearstick and alloy bushes int othe cradle
Got my engine back from my engine builder AMAC in northallerton a propper old school competition engine specialist, they have polished the crank which is std/std balanced it along with the flywheel (which they have also lightened and machined) and the clutch cover
they then refitted the Crank for me just so I know it's right!
I then set about refitting the rest of the engine together complete with a new oil pump and gated baffle for the sump which is currently away having an oil return welded in as I am going to be breathing from both sides of the block and returning to the sump below the oil level
To bring it up to date today I got my inlet manifold fitted and sorted out the breather connections the turbo side pipe is fitted with industrial pipe insulation to prevent the heat from the manifold burning it, also finished off the water pipe mods as im not using a heater in the car I used a 2wd solid pipe turned round to run across the top of the exhaust manifold this meets up neatly with the pipe from the oil modine a moment of genius if I say so myself
Old 12-12-2010, 07:20 PM
The Youth.
The Youth.'s Avatar
T34.48 light blues so around 360 bhp,don't any anymore as thats about it for the transmission specially as it is a race car so isn't going to get an easy time of it! lol
At that power level the 4wd manifold will be fine
steve
Old 12-12-2010, 08:09 PM
RONNIE AMIS
RONNIE AMIS's Avatar
looking good mate, will keep an eye on this now,
when does your season start?
Old 12-12-2010, 08:17 PM
BRAM
BRAM's Avatar
Seen your car at croft before and it seemed to go quite well so should be great with the yb in it!!
How are you getting on in the northern saloons? Would love to do something like that might start with a few trackdays first.
Are you still a member of the cumbria group?
I came to a few meets before but took my car off the road so cant get there now, when i get my car back out i might pop to some.
Cheers Bram
Old 12-12-2010, 08:50 PM
The Youth.
The Youth.'s Avatar
cheers ronnie, season starts in late april so I'm doing ok for time at the mo..that will no doubt change tho lol
Bram, Cleveland group
yes m8 still a member, you don't need your car on the road to come to the meetings, get yourself along m8
as for my first season I finished 3rd in class and 13th overall, which is far better than I was expecting
steve
Old 12-12-2010, 08:54 PM
Dicko&Vacant
Dicko&Vacant's Avatar
looking good steve
Old 12-12-2010, 09:31 PM
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Good luck with the conversion Steve
Old 12-12-2010, 09:37 PM
BRAM
BRAM's Avatar
steve
Ooops sorry i meant Cleveland group lol
not to bad for your first season then should be better next year with more power good luck mate and keep the updates coming
Cheers Bram
Old 12-12-2010, 09:50 PM
Nash
Cake lover!
Nash's Avatar
Will you have to move up a class with upgrading the power at all?
What were the sort of costs involved in you first season with getting the car to comply with the regs etc, PM me is needs be.
Old 12-12-2010, 10:39 PM
lee2cossies
lee2cossies's Avatar
Very nice project! Iv always fancied an xr4x4 with a yb. The 24v's are brilliant engines but just lacking that bit more oomph,should be very competitive now.
Old 13-12-2010, 05:12 AM
The Youth.
The Youth.'s Avatar
I stay in class B Treaded tyres (over 2000cc as the car is now 3400cc with the 70% loading for the turbo)
typical prices for first timers this is about what I paid (I got my medical done on the cheap tho)
go racing pack Ł60
ards test Ł275
medical Ł100
National B licence Ł51
safety gear, suit ,helmet, boots, gloves, Ł700
transponder Ł250 (secondhand) Ł350 new
championship entry Ł115
each race weekend entry fee Ł280
car preps about 2k(to convert from track car to race car) inc tyres at Ł450 for 4 toyo R888 not to mention many hours of work!
hopefully m8 thats the plan!
Old 13-12-2010, 07:24 AM
RSRoy
RSRoy's Avatar
I like this Steve.
Keep us updated
Old 13-12-2010, 07:30 AM
phatfordxr4i
phatfordxr4i's Avatar
good luck with it mate might see ya late in the season, have you got cadwell or donington next year if so what date?
Old 13-12-2010, 08:01 AM
The Youth.
The Youth.'s Avatar
Got cadwell m8 not sure what date (may or june I think) will pm you when I check when I'm at home
steve
Old 13-12-2010, 09:56 PM
The Youth.
The Youth.'s Avatar
picked up my sump today got the fitting welded on as a freebie by one of our contractors.
also picked up a brand new 4x4 TPS for the Level 8 I am going to use
steve
Old 13-12-2010, 10:03 PM
boothy
boothy's Avatar
Good work,will come and watch next year mate
Old 13-12-2010, 10:11 PM
The Youth.
The Youth.'s Avatar
cheers m8 Im at oulton park on the 13th August
steve
Old 13-12-2010, 10:15 PM
boothy
boothy's Avatar
steve
Good stuff 40 mins from mine
Old 14-12-2010, 11:19 PM
The Youth.
The Youth.'s Avatar
Quick update tonight I fitted the power steering pump, alternator and aux belt
steve
Old 15-12-2010, 05:43 PM
M K
M K's Avatar
any reason why your running that set up with the pas and alt on the same side rather than pas on the inlet side? just curious,
Old 15-12-2010, 06:12 PM
dingla rs
dingla rs's Avatar
i remember seeing this at croft coming back in to pits on wagon ,gna be a nice toy with the yb
Old 16-12-2010, 05:33 AM
The Youth.
The Youth.'s Avatar
The set up is a late 4x4 / esc cos one I chose to go this way as the bracket for this set up came with the engine and I already had all the power steering pipes for this set up, made it all very easy and cheaper to build
Yes m8 that was me!
Offside engine mount failed causing the offside front inner cv joint to come apart at 80 mph... Went with big bang and scared the shite out of me and my passenger!
Had a spare tho so got back out again
Steve
Old 16-12-2010, 06:02 AM
scottyrs
DURHAM RSOC
scottyrs's Avatar
looking good bud going to be mint
Old 16-12-2010, 07:49 PM
Yes m8 that was me!
Steve
Yeh and i shit myself cause i was sat in the passenger seat.
Steve your a good quick driver mate.I hope you do even better with the YB in the sierra.
Old 19-12-2010, 10:55 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
steve , how much did amac charge you for the work mate ,
considering getting my bottom end balanced as one of the rods was replaced
also what services do they offer , polishing ect ?
beef
Old 24-12-2010, 06:06 PM
phatfordxr4i
any idea when your at cadwell yet?
Old 25-12-2010, 08:01 PM
The Youth.
The Youth.'s Avatar
Yes m8 it the 21st/22nd may
steve
Old 03-01-2011, 07:06 PM
The Youth.
The Youth.'s Avatar
Been down to unit today with me dad and removed the V6 engine, everything went smoothly for a change!
seperated the engine and box and removed the front diff and other ancilarys that will be transfered over to the new engine
steve
Old 03-01-2011, 08:02 PM
I was in the car with him when it went.I really shat myself.I thin Steve shit himself too.
Old 03-01-2011, 08:05 PM
Top work Steve.Have you got a buyer for your old engine.
Old 03-01-2011, 09:49 PM
The Youth.
The Youth.'s Avatar
not going to sell it straight away glenn, going to keep it just incase the is a big issue with the yb, will put it up for sale later in the year all being well
steve
Old 03-01-2011, 10:08 PM
Miller 3
Miller 3's Avatar
Looking good Steve
Old 03-01-2011, 10:19 PM
dingla rs
dingla rs's Avatar
just remeber as it came past with doors open lifted with the cage glen i missed it going off
look forward to seening it this year with the yb
Old 03-01-2011, 10:40 PM
The Youth.
The Youth.'s Avatar
least it proved I fitted the cage properly lol
steve
Old 03-01-2011, 10:46 PM
-beefy-
-beefy-'s Avatar
cough cough ,
amac - charge - cough cough
Old 04-01-2011, 12:59 AM
Alps Pacino
Alps Pacino's Avatar
good progress, puts my effort to get the ibiza running again to shame lol
can see the blue beast lurking in the back ground
Old 08-01-2011, 11:19 PM
The Youth.
The Youth.'s Avatar
Had a busy day today with plenty of new parts arriving, firstly the other day my msd chip and -34 arrived aswell as my front diff strengthening plate and today I picked up my cambelt cover and hydraulic clutch,then tonight I managed to spend a few hours in the garage and fitted the plate to the front diff, then fitted the diff to the engine.
At the unit the other day I removed the fuel pump and carrier and tonight after sorting the diff I set about making the new pump and filter fit, being an xr4x4 the filter isn't in the normal cossie position next to the pump so I made a bracket up and mocked up the new set up using my 044 pump that I will be using.
I then cleaned up and painted the pump carrier with some smoothrite to tidy it up a bit, tommorow I will fit the clutch cylinder to the gearbox
steve
Old 09-01-2011, 09:51 PM
The Youth.
The Youth.'s Avatar
Got a couple more hours in the garage tonight and re assmbled the fuel pump cradle after painting it and fitted the slave cylinder to the gearbox.
steve
Quick Reply: Cossie YB into my race car project*update RR print out!* 02/4/11
