My Project G3 RWD Escort
Lucifer II - 666
nice pic bud but you dont have start a new thread every time you make an update
https://passionford.com/forum/restor...wd-escort.html
https://passionford.com/forum/restor...scort-rwd.html
My G3, does anyone know where i can get replacement lamps for this conversion, its a real ford jobie, tried Hella light with no joy, any help please.
didnt realise that, i thought that older threads people dont bother responding as there not in plain sight.
new picture added for my RWD C20LET gatrac escort.
Got the new Hella lights now, woudnt believe it they sold them 1mile from where i live how uncanny is that. Previously searched the web high and low, found hella catalog and outlets, lucky for my one outlet was local, Wiring is now complete. If anyone does this conversion i have complete knowlage of wiring a C20Let to an RS Turbo/XR3i if you require any help. It wasnt easy took me 2 weeks to work out where it all should go. Looking back it is now so simple. Not. lol.
Tried to get a side view, but it raining didnt want to take her out. Painted by me, first time i ever tried it it, very hard work, but looks good. To finish her off she needs, plumbing up, fuel and coolant, extending the battery cable as there in the boot with fuel tank, and brake pipes, thats about it, shes got a GT35 turbo now and stainless manifold, phase 3 ecu, hopefully when its done trying for around 400/450 bhp mark, engine is well uprated H- beam rods mahle pistons, knife edge crank, i could go on but dunna want to bore you.
The arches are alluminum tarmac arches as are the sills, dont know who fabricated them, but are perfect fitment, the car was built by Denis Moody from Gartrac so they must have made the arches and sills
Yer i know what you meen about mirrors, just trialing them to see what they look like. not that keen probally replace em anyway with the originals. thanks for the comment, cheeRS
Seats have gone in today, fuel lines are in. just have gearbox to fit, windscreen to get, also need a dash, and some split rims to fill them arches, almost done, cant wait to test her on the road, gona be wild lol.
Does anyone know how i can run a speedo on this engine as the gearbox is R25/28 gearbox and has no drive inside the box to drive the cable. im told there is a sensor on the engine somewhere and goes to the ecu, but cant find any wiring for this.
seats are in now, just need a top half dash, and a front screen. gearbox is now sorted, using a R28 omega v6 gearbox, just got 2 get a v6 calibra flywheel and clutch, some hoses and thats about it.
Lucifer II - 666
drag it out that unit and get some better pic's taken
Ive sorted it now, took the spacer out of the back of the gearbox and put a speedo drive gear in, and put a new gearbox seal back on
Dragging it out this week for some full blown pics. J ust decided to change inlet manifold for an aftermarket one, maybe a swedish plenum welded to the original inlet, with big cozi throttle body, if i can get one cheep enough, i had one from ebay last year for my 3 door and it was the worse made manifold ive ever seen and the guy is knocking wm out for 230 buff. Id be ashamed if i sold owt like that to anyone, but hey thats just me.
Spec now up
G3 ESCORT RWD SPEC
· 5 LINKED CAPRI ATLAS AXLE
· FULL 2WD COSWORTH REAR DISC CONVERSION
· NEW AVO COILOVERS
· FULLY FIRE WALLED
· GARTRAC ALLOY TANK IN BOOT
· NEW PANHARD RODS
· BIG DIFF TUNNEL
· BIG GEARBOX TUNNEL
· GARTRAC ALLOY TARMAC ARCHES
· BIAS PEDDAL BOX
· R25/28 GEARBOX
· V6 FLYWHEEL AND CLUTCH
· TURRETED
· GARTRAC ROLL CAGE
· CUSTOM DASH
· MK2 ESCORT QUICK RACK
· NEW ADJUSTABLE TCA,S
· NEW ADJUSTABLE TRACK ROD ENDS
· NEW ANTI ROLL STRUTS ADJUSTABLE
· CAPRI FRONT BRAKES
· NEW CROSS DRILLED DISCS FRONT/REAR
· NEW MK2 ESCORT COILOVERS
· C20LET ENGINE PHASE 3
· KNIFE EDGE CRANKS
· UPRATED BEARINGS
· STEEL RODS
· LOW COMP PISTONS
· STEEL MULTILAYER HEAD GASKET
· GT 35 TURBO
· CUSTOM EXHAUST MANIFOLD
· CUSTOM WIRING
· 35MM EXTERNAL WASTEGATE
· S/S CUSTOM EXHAUST
· CUSTOM MADE INLET MANIFOLD
· ALLOY TANKS
· ALLOY RAD
· BIG INTERCOOLER
· OIL COOLER
· GERMAN SPEC FRONT LIGHTS
That’s about it for now still buying parts, seems endless, still a good way to go yet. Was hoping to get it done for summer, but summer is all but upon us, where has the time gone. Looks like late autumn now or next spring unless I win the lottery. I think thats about it for now.
· NEW AVO COILOVERS
· FULLY FIRE WALLED
· NEW PANHARD RODS
· BIG DIFF TUNNEL
· BIAS PEDDAL BOX
· R25/28 GEARBOX
· TURRETED
· GARTRAC ROLL CAGE
· CUSTOM DASH
· KNIFE EDGE CRANKS
· UPRATED BEARINGS
· STEEL RODS
· LOW COMP PISTONS
· GT 35 TURBO
· CUSTOM WIRING
· ALLOY TANKS
· ALLOY RAD
· BIG INTERCOOLER
· OIL COOLER
ive got a wiring issue again, no ground activation from the ecu, fuel pump relay to terminal 3 on motronic ecu is live but wont switch to earth, if theres anyone who has wired these c20lets up could you please help.
Update. i now have me wheels on, Weller steels 14 x 8 re powder coated and brand new 205 x 60 x 14 rubber. not a deal to do now, brake lines, fuel lines, rad cooler and exhaust and an external wastegate. Could do with a nice front lower front spoiler for it to finish off the body work. Ive also had a motorsport zebra stripe kit for it but dont know whether it will look right or not.
