My Mk1 Escort With H.P.E N/A Cosworth
Old 01-04-2009, 06:26 PM
mk1ian
mk1ian's Avatar
Default My Mk1 Escort With H.P.E N/A Cosworth
heres some pics of my mk1 escort that i ve owned for nearly 4 years.
it had a 1660,1300gt pistons,bcf3 cam and mild head work, a nice useable fast road Harris x-flow in it when i brought it
Then i put some 7x13 RS four spokes with 175/50/13's on it
after having the car for a year i decided to goto town on it and got Ron Harris to build me this
its a nice fast road N/A cossie spec is:
cosworth crank
cosworth rods
accralite forged pistons
ported head - 27mm with valve guides cut down
BP300 cams
solid lifters
standard valve sizes
3 angled valve seats
double valve springs
vernier pullys
twin 48 webers
bosch dizzy
i also up rated pretty much everything else on the car, tran-x straight cut box,quaife ATB LSD with atlas size bearings and half shafts,bias hyralic pedel box,wilwood 4 pot brakes and 265mm disc,group 4 alloy rad,high torque starter motor
Heres some pics of it in the car
It made 224bhp which is more than good enough for what i use the car for and had a good summer with the car,a few teething problems with the carbs as you do but the engine was strong and pulled like a train.
The dizzy got stuck on full advance in november and blew the head gasket, no ones fault just one of those things, it made me think about updating to Throttle bodies and full management so i decided to go for it, while the engine was out had the engine bay spruced up,
and heres some pics of the engine back in and a test fit of the throttle bodies (ignor the horrible green rocker cover it aint staying!)
and thats as far as i ve got so far! hoping to get the car done for the summer but we ll see how the overtime at work goes
Old 01-04-2009, 06:43 PM
jason_nike
jason_nike's Avatar
That car just looks fantastic.
Is there a lot of work to fit the cossie engine as would like to do the same but curious on cost etc
Old 01-04-2009, 06:48 PM
Rs1
Rs1's Avatar
Excellent, really like the old skool fords.....especially with NA for a change.
Speedflow do some nice fuel fittings in black(stealth range), would go well with the black/silver TB's.
Old 01-04-2009, 07:00 PM
mk1ian
mk1ian's Avatar
the engine fits straight in, just use rs2000 engine mounts, there are a few problems with the manifolds running too close to the brake master cylinder and throttle and clutch cables but a bias pedel box with a grp4 throttle pedel sorts these problems out
the cost umm lets just say if you do it properly and uprate the rest of the car (gearbox,axle,pedel box,cooling system,fueling) it ll cost some where between lots and loads
decent fresh built engine Ł3-4k complet with flywheel,clutch,cover plate,sump,dizzy,leads
plus either Ł800 for carbs or Ł2500 for management and T/B's
gearbox Ł1300
pedel box Ł250
manifold Ł400 plus wat ever system after that
radiator Ł300
LSD Ł450
halfshafts Ł300
alloy bell housing Ł140
starter motor Ł150
decent brakes Ł450 right upto Ł1200 depending on what you want
and various other bits n bobs needed
the noise and look of a N/A cossie in a mk1 escort PRICELESS
Old 01-04-2009, 07:01 PM
mk1ian
mk1ian's Avatar
i m gonna use rubber hose for the standard look
Old 01-04-2009, 07:06 PM
Karl 3dr
Karl 3dr's Avatar
Absolutely gorgeous car mate!!
Old 01-04-2009, 08:02 PM
Mr RS500
Mr RS500's Avatar
Thats the bollocks
what you done with the other carbs and mannifold ??
Old 01-04-2009, 08:07 PM
Rab
Fucking superstar........
Rab's Avatar
I want it!! Thats just ace!!
Old 01-04-2009, 08:12 PM
scotty86d
scotty86d's Avatar
That is just right!! NIce one
Old 01-04-2009, 08:26 PM
mk1ian
mk1ian's Avatar
Originally Posted by NORTH YORKS RS SPARES
Thats the bollocks
sold the carbs and using the manifold again for the t/b's
Old 01-04-2009, 08:38 PM
AndyKam
AndyKam's Avatar
Wow, really like that. Its
Old 01-04-2009, 08:41 PM
marky_g
Fleet Manager
marky_g's Avatar
thats the bollcocks
Old 01-04-2009, 08:44 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Had a N/A cossie in my MkV Cortina years ago, sounded ace
Nice work mate
Steve
Old 01-04-2009, 08:46 PM
RS Juto
RS Juto's Avatar
Superb, absolutely gorgeous I want i want
Old 01-04-2009, 08:54 PM
Russ_Cossy
Russ_Cossy's Avatar
perfect
Old 01-04-2009, 09:01 PM
smitsturbo
smitsturbo's Avatar
Originally Posted by Russ_Cossy
perfect
wouldnt change a thing
Old 01-04-2009, 09:03 PM
jason_nike
jason_nike's Avatar
gearbox Ł1300
pedel box Ł250
radiator Ł300
LSD Ł450
halfshafts Ł300
starter motor Ł150
Thanks for the info, will need to sve
Old 01-04-2009, 09:29 PM
Lee Reynolds
Lee Reynolds's Avatar
My god that looks amazing! Christ ive only just finished my RS1600i resto, yet to MOT it and im fancying a mk1 lots! DOH!
Old 01-04-2009, 09:36 PM
Steve the Plumber
The original Rouge Trader
Steve the Plumber's Avatar
Nice, and you cant beat a "Harris engine".
Old 01-04-2009, 10:49 PM
Its Dave
Its Dave's Avatar
Thats well nice, get some more pictures up
Old 01-04-2009, 10:55 PM
MikeR
MikeR's Avatar
That looks very nice,
Paul do you have any rs 4 spokes that are 7 3/4" wide?
Thanks
Mike
Old 01-04-2009, 11:08 PM
JonnyBravo
JonnyBravo's Avatar
Stunning !
Just had a mate over who has a nigh on identical althougn not as clean Mk1 with a xflow in it, trying to convince him to see the light and junk the xflow and fit a xe with the tb's he has kicking about due to power and cheap costs. He's not a bit interested his loss.
Has the engine spec of the YB changed at all since you fitted the tb's ? which ones are they out of interest ?
Old 01-04-2009, 11:47 PM
Chopshop85
Chopshop85's Avatar
Im pretty sure Ive seen you up classic ford day a few times with the x-flow in it!
Fantastic looking car mate!
Old 01-04-2009, 11:55 PM
BigPeBe
BigPeBe's Avatar
Can't really make up anything better to say
Old 02-04-2009, 01:51 AM
fezzajsy
fezzajsy's Avatar
awesome mate
Old 02-04-2009, 06:34 AM
That looks mint.Well done mate.
Old 02-04-2009, 06:45 AM
Twellsie
Twellsie's Avatar
that is stunning!!!
Old 02-04-2009, 07:07 AM
Mark V8
Mark V8's Avatar
Perfect
Mark
Old 02-04-2009, 07:31 PM
wess-rs
wess-rs's Avatar
Love it !!
Old 02-04-2009, 07:44 PM
paprst
paprst's Avatar
Please make a vid ,so that we can hear it too!!
I love it
Old 02-04-2009, 08:02 PM
hitchwest
hitchwest's Avatar
that looks mint
Old 02-04-2009, 08:16 PM
Nelson
Nelson's Avatar
Look's nice. What is the power of the engine air?
Old 02-04-2009, 08:19 PM
mk1ian
mk1ian's Avatar
thanks for all the kind comments i ll be posting more next week as i ve got the week off to hopefully finish the car ready to be mapped
Old 03-04-2009, 01:03 AM
melspec1
melspec1's Avatar
FOOKEN sweet mate'' FOOKEN sweet!
Old 03-04-2009, 08:30 AM
Munch
Mr. Sparkle!
Munch's Avatar
Awesome car!
Old 03-04-2009, 08:51 AM
CraigoScott
CraigoScott's Avatar
that is sweeeeet!
Old 03-04-2009, 05:39 PM
andy escos
andy escos's Avatar
looks absolutely stunning ca you put some pics up of the rest of the car
Old 03-04-2009, 06:37 PM
Stunning
Old 03-04-2009, 06:43 PM
doctor stavros
AMG C32
doctor stavros's Avatar
Car looks lovely! out of interest, what made you go for a n/a over turbo, and why the green rocker cover?
Old 05-04-2009, 10:43 AM
roro22
roro22's Avatar
I love that, it looks so clean and fresh
must sound amazing too
Quick Reply: My Mk1 Escort With H.P.E N/A Cosworth
