V8 Sierra 2WD
Old 28-03-2011, 09:03 PM
  #161
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
yeah , if that was a ls motor id be loading the yb up as we speak mark
Old 16-04-2011, 10:08 PM
  #162
whizzisat114
whizzisat114's Avatar
Your just being modest
the fab work and welding on the exhaust is top notch from what i can see
Old 16-04-2011, 11:36 PM
  #163
BON_300
BON_300's Avatar
i`m sure there are more pics by now
Old 17-04-2011, 12:13 AM
  #164
kieran_macca
kieran_macca's Avatar
looks great maybe i should stick one of those into mine lol
Old 17-04-2011, 07:41 AM
  #165
focus 4x4
focus 4x4's Avatar
Love it Mark , ill have to drop by at some point for a gander! ;o)
Old 17-04-2011, 08:20 AM
  #166
Mark V8
Mark V8's Avatar
You are welcome to pop round and have a look
Started on tacking the passenger side
I will get there in the end
Mark
Old 20-04-2011, 06:10 PM
  #167
BON_300
BON_300's Avatar
What wheels have you got in mind ? Or will you tube the rear end in pro-street style ?
Old 20-04-2011, 08:47 PM
  #168
Mark V8
Mark V8's Avatar
RS 7 spokes
I want to keep it fairly low key.
Old 20-04-2011, 09:24 PM
  #169
whizzisat114
Look's nice on those wheels
Old 22-04-2011, 02:43 PM
  #170
scoooby slayer
scoooby slayer's Avatar
awesome fabrication work there
Old 17-05-2011, 05:45 PM
  #171
Mark V8
Mark V8's Avatar
Getting there with passenger side.
Had loads of trouble with the tungsten electrodes melting that turned out to be a bad batch of argon, that along with a mask that was not sensitive enough to low power welding and my inexperience with TIG has lead to some not very pretty welds
New batch of gas and better mask has helped.
Now I need to tidy the shed !
Mark
Old 17-05-2011, 06:24 PM
  #172
timbhp
timbhp's Avatar
looks ace keep up the good work
Old 18-05-2011, 06:37 AM
  #173
merkwerke
merkwerke's Avatar
Default Fellow V8 fan
Very impressive craftsmanship Mark. Here are a few projects I've built or sold parts for the building of.
Keep up the good work. All the best, James
Old 18-05-2011, 06:57 AM
  #174
whizzisat114
Very impressive
Old 18-05-2011, 07:42 AM
  #175
dojj
Resident Wrestling Legend
dojj's Avatar
those engine bays look just a little on the tight side
Old 18-05-2011, 05:55 PM
  #176
Mark V8
Mark V8's Avatar
Thanks for the encouraging comments.
The overhead cam engines look a tight squeeze
You have been a lot busier than me !
cheers
Mark
Old 18-05-2011, 08:00 PM
  #177
merkwerke
merkwerke's Avatar
Not as busy as you might think. I've been doing this for several years now and I make install kits for both the pushrod and OHC engines. Except for drilling 2 holes, 302 pushrods are a bolt in. Minor hole enlarging of the firewall at the brake booster mount is required for the mod motors. We did the engine install on the black car in about 2 hrs!! As for fit, except for front to back length, the engine compartments of a Merkur, nee Sierra, is wider than the Mustangs these engines came out of!! It takes the better part of 8 hours to install headers on a 4.6 in a Mustang. It's about 30-45 min same engine in an XR. And 315RWHP from a breakers yard engine is pretty good going. It cost the equivelent of about 400 quid. And it weighs 40lbs LESS the the 2.3 4cyl it replaces!! I have a Camaro/Firebird T56 in mine. 1800 RPM @ 80 MPH and 26mpg. Best my 2.3 ever gave was 23MPG. Soon to have an 8.8" Independent rear diff from a Cobra/Lincoln Mk8 with 4.10 gears and a new front Kmember with a new front suspension design. This will allow (all at once) the V8 swap, big brakes, front mount sway bar, new suspension with 1.5" height reduction built in. You're gonna LOVE your car! Cheers!
Old 05-06-2011, 05:37 PM
  #178
Mark V8
Mark V8's Avatar
I had to remove the ARB to get the drivers side header off for welding so made up a couple of spacers to give clearance between the ARB and gearbox.
Then I unpicked the drivers sider header one pipe at a time and welded all the joints, after that they were welded back to the header flange and the merge cone widget was welded between the 4 pipes. The welds arn't pretty but should be strong enough
Can't believe how much work these have been !
Old 05-06-2011, 06:40 PM
  #179
whizzisat114
Craking work
Old 09-06-2011, 05:30 PM
  #180
TRUEBLUE1968
TRUEBLUE1968's Avatar
Keep at it !!!!!
Its worth the effort
Size:  77.0 KBName:  IMAG0246.jpg
Here are my specs.
3.64,T5,Front Coilovers 302 9.7-1, AFR 185s,comp cam 284hr,
comp cam 1.6 gold rockers,Parker Funnel Web converted to F.I.,35s,Equal length headers,3" Y to 4" out,Controlled by Megasquirt2 Extra
Old 09-06-2011, 05:54 PM
  #181
Mark V8
Mark V8's Avatar
Originally Posted by TRUEBLUE1968
Keep at it !!!!!
Here are my specs.
Looking good
Whats the 284HR like to live with ?
Any vids of it online anywhere ?
I am planning on running a single 3 inch system, is it too small ??
cheers
Mark
Old 09-06-2011, 06:21 PM
  #182
TRUEBLUE1968
Its not too bad with my stock displacement and Megasquirt.
I had 3" Y to 3" in the beginning, But foud that 4" was much better drivablity and throttle response wise. If you can go 4" single, or 3" dual you wont be sorry
Old 12-06-2011, 06:14 PM
  #183
Mark V8
Mark V8's Avatar
At last the headers are finished
Now I need to connect them to a 3 inch Cossie system.......
Old 12-06-2011, 08:03 PM
  #184
whizzisat114
Work of art
I wish i was half as good of a fabricator as you.
Top notch.
Old 12-06-2011, 08:17 PM
  #185
-beefy-
-beefy-'s Avatar
guess whos been pricing up v8's stateside lol
Old 12-06-2011, 08:38 PM
  #186
Mark V8
Mark V8's Avatar
whizzisat114 - you are far too flattering, my welding is probably strong enough but not so neat up close
Beefy - you know you need a V8 in your life
I'm feeling a bit gutted today as I've just taken a deposit on my bike...
Cash injection needed to keep the Sierra moving forward and I now have to drive to work in a Fiat
Old 12-06-2011, 09:19 PM
  #187
-beefy-
-beefy-'s Avatar
afpmsl
wounder on the xjr mate , being a big lad its a bike thats always appealed to me
yea , got in touch with a guy about an ls ,
just waiting to hear bk about shipping ...... but hes got turnkey ls1-2's with 6 speeders for las little as 5k usd
wonder what my yb's worth lol
Old 12-06-2011, 09:25 PM
  #188
whizzisat114
Lovely bike
Id love to v8 my focus but ill end up yb'ing it
Old 13-06-2011, 03:02 PM
  #189
marky_g
Fleet Manager
marky_g's Avatar
looking good
Old 18-06-2011, 05:52 PM
  #190
Mark V8
Mark V8's Avatar
I'm sick of doing exhausts so have made a start on hydraulic clutch conversion.
0.75" master cylinder with a 6:1 pedal ratio as recommended by the release bearing manufacturer.
Slip on Mcleod release bearing.
Having a right fight trying to get the ARB back on
What's the best/easiest way of lining it all up ?
Old 18-06-2011, 07:25 PM
  #191
whizzisat114
Leave mountings loose to body get one tca all on. Then using a ratchet strap pull the two ends together and bolt other tca up
Works for me anyway
Old 18-06-2011, 07:34 PM
  #192
kjc300
kjc300's Avatar
Mark, do yourself a favour and make the bolts on the master cylinder captive (weld the heads onto the support plate) As it makes it so much easier to change the master cyl if need be (to adjust the clutch bite point by changing sizes,and if you've used a wilwood cylinder!! )
Also agree on the ARB, put one side on and use a ratchet strap to get the other in.
Old 18-06-2011, 09:10 PM
  #193
Mark V8
Mark V8's Avatar
I am going to weld the bolts in place, might weld the support plate to the bulkhead as well for extra support.
Master cylinder is a Girling one and I'm hoping good old English workmanship will stop leaks
One area of concern is the throw out bearing, instructions were a bit dodgy so I Googled the Mcleod part number and found loads of people complaining of leaks
I will 'phone Real Steel in the week and make sure they have sold a few without complaint. It's a real bitch to change if fluid starts to leak and the engine and box have to come out to get to it!
Old 19-06-2011, 01:32 PM
  #194
andy escos
andy escos's Avatar
your exhaust headers look excellent
are you sure you worked out your pedal ratio correct as the hydraulic clutch on my cossy pedal box worked out to 3.5to1 not 6to1.
Old 19-06-2011, 05:52 PM
  #195
Mark V8
Mark V8's Avatar
Pivot point to rose joint is approx 50mm and pivot point to the end of the pedal is approx 300mm so it's close-ish to 6:1 if I've worked it out right
Too late now anyway
Old 18-07-2011, 02:22 PM
  #196
super-ron
super-ron's Avatar
fantastic fabrication on the headers
Old 18-07-2011, 02:55 PM
  #197
Mr C
Mr C's Avatar
You've moved the ARB forward a massive amount, what is it an inch? How is that going to drive with such extra front trail, or are you moving the front crossmember/ TCA mounts forward too?
Old 18-07-2011, 04:35 PM
  #198
Mark V8
Mark V8's Avatar
The spacers are 20mm thick and because they sit at an angle it does not mover the TCA forward anywhere near that much.
BUT when I tried to bolt it all up for a trial fit it was a real struggle and the TCA would be straining the bush where it fits the front crossmember so I gave up
I will probably end up thinning the spacers down a fair bit and modifying the bellhousing to clear the ARB.
Engine and gearbox are out now and I've finished easing the transmision tunnel for clearance on the bellhousing.
I've also bought a spit and the next job is a complete strip down of the shell to bare metal the underside and fix any rot then find a painter to give it a respray.
Old 18-07-2011, 05:17 PM
  #199
ShiftyOldScoob
ShiftyOldScoob's Avatar
Nice !
Old 27-08-2011, 10:36 PM
  #200
Mark V8
Mark V8's Avatar
Had the engine and box in and out a few more times to fettle the transmission tunnel with a hammer for clearance then started the strip down to sort the rust / bodywork.
All the wiring loom and sound insulation is now removed.
I made a couple of dollies to keep it mobile using some heavy duty angle and castors scrounged from work but all four wheels swivel at the moment and it's like a dodgy shopping trolly to move around !
Quick Reply: V8 Sierra 2WD
