Audi 20v Turbo powered Rover 25 (some new pics page 3)
Old 20-12-2006, 08:21 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Default Audi 20v Turbo powered Rover 25 (some new pics page 3)
I did start a thread ages ago but can't find it
This is the car as I bought it from the MG racing auction..
As you can see it was yellow originally
here's the Audi engine trial fitted
the original brakes
Added some VW golf vents into the bonnet to aid cooling in the turbo area
Decided to return it to yellow!
It's going to need to stop..
the wheels
The bulkhead modified to accept the modded bias pedal box
electric power steering
Engine and gearbox test fit
Rover alternator on Audi engine
Adaptor plate Audi engine to Rover gearbox
Clutch plate
clutch cover (anyone know what wording has been ground off it?)
Rover sized flwheel with Audi bolt pattern
New spherical bearing top mounts made and Leda strut
Adjustable TCA
Will bolt it all together over Christmas..
Old 20-12-2006, 08:24 PM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Lovely Martin
Old 20-12-2006, 08:25 PM
TimC
TimC's Avatar
jesus alots gone on since i last seen the original topic.
quality
Old 20-12-2006, 08:26 PM
Zetecfiesta
Zetecfiesta's Avatar
looking good!!
Old 20-12-2006, 08:43 PM
carlo
carlo's Avatar
COol conversion martin
Old 20-12-2006, 09:05 PM
MAD EVO 4
MAD EVO 4's Avatar
Old 20-12-2006, 09:20 PM
dave cos4x4
dave cos4x4's Avatar
you do things right Martin.
Old 20-12-2006, 09:21 PM
CraigoScott
CraigoScott's Avatar
Old 20-12-2006, 09:51 PM
Munch
Mr. Sparkle!
Munch's Avatar
top stuff
Old 20-12-2006, 10:02 PM
Brian
Brian's Avatar
Brian
Old 20-12-2006, 10:08 PM
tracktoy
tracktoy's Avatar
looks much better in yellow imo
should be fun when its finished
Old 20-12-2006, 10:23 PM
Mr.h.
Mr.h.'s Avatar
really nice project
Old 20-12-2006, 10:36 PM
Eddie RST
Eddie RST's Avatar
Anouther truly crazy project good work
Old 20-12-2006, 10:46 PM
AndyNo1
AndyNo1's Avatar
What engine is that? I know its the 1.8T but what power? 150, 180 or 225?
Engine mods/plans?
Old 20-12-2006, 10:53 PM
tocca
tocca's Avatar
Will be keeping my eye on this
Old 20-12-2006, 11:42 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Awesome.
What electric PAS pump is that Martin?
Old 21-12-2006, 06:50 AM
Franco
Franco's Avatar
What are you doing to the lump Martin? I doubt it'll stay standard!
Old 21-12-2006, 06:54 AM
Black_RS
Black_RS's Avatar
nice one! Is it for 'personal use' or customer? I like it with the rover wheels - if it had tinted windows (like they all seem to round here) you wouldn't see the cage and it'd be a real sleeper
Old 21-12-2006, 07:23 AM
Martin-Hadland
Engine mods/plans?
225hp Audi TT unit which will run about 260 ish hp to start with.
Old 21-12-2006, 09:22 AM
danrs2k
danrs2k's Avatar
Old 21-12-2006, 10:43 AM
Fastas
Fastas's Avatar
great project
Old 21-12-2006, 11:21 AM
AndyNo1
AndyNo1's Avatar
Engine mods/plans?
Even with the 260hp that will be quick. Nice one Mart, keep us updated.
Old 21-12-2006, 11:28 AM
AGAR-COSWORTH
Redumbdancy
AGAR-COSWORTH's Avatar
Cool project - will be a bit of a sleeper when its finished.
Old 21-12-2006, 04:41 PM
Old 21-12-2006, 04:56 PM
Alps Pacino
Alps Pacino's Avatar
martin-reyland
Have you looked into big hp 20vt motors cause ther dont seem to be many people that have done much more than the ihi 330bhp conversions
I have just aquired a gt30 for mine but obviously ant to do intrnal mods ie crank rods ppistons and head work. Just wondered if you can source the bits or if you know the right places to start looking
Cheers Mark
Old 21-12-2006, 06:29 PM
Martin-Hadland
Originally Posted by Alps Pacino
martin-reyland
Cheers Mark
Making the power out of these engines is not going to be a problem and 350hp can be had without going internal. I will tune mine in the future but for now I dont want the project to run away with itself financially (it has a bit already!) so will be using standard parts to start with.
Old 21-12-2006, 06:54 PM
Alps Pacino
I know 350 is atainable but i have the moto of do it right do it once. I'm wanting a bullet poof engine to start with with circa 400bhp.
I know people use je pistons and been recomeded some make of rods but i'm just worried about the crank and not sure what cr to go for?????????????
I dont want it to low that its wank off boost but not to high that boost is limited
Old 21-12-2006, 07:31 PM
xr-stu
xr-stu's Avatar
whats been done with the clutch/flywheel to take up the thickness of that adaptor plate? id assume if you just bolted it in between and didnt do anything else, the input shaft on the box wouldnt make proper engagment with the clutch and neither would the release bearing?
very interesting car!
Old 21-12-2006, 09:00 PM
Rossco
Rossco's Avatar
Proper nice project, does look way better in yellow. Should be a Rover/MG that you would be proud to own, once finished.
Old 21-12-2006, 09:08 PM
Martin-Hadland
all that has been calculated and the results are the flywheel you see..
Old 21-12-2006, 11:31 PM
EssexMikeSi
EssexMikeSi's Avatar
looking good mate, cant wait to see the next set of update pics
Old 22-12-2006, 07:10 AM
jameswrx
jameswrx's Avatar
Mr. Clutch?
Old 22-12-2006, 11:51 AM
xr-stu
xr-stu's Avatar
ah right so its a one off flywheel not just a modded one?! shouldnt known really
so i guess you just made the 'offset' from crank mating face to cluch mating face bigger by the thickness of that plate? could that be done safely with a spacer between crank and flywheel you recon? or a spacer welded to the flywheel? just thinking aloud etc as ive always wanted to use a honda VTEC lump in a fiesta, might be in a financial psoition to do it later next year so is handy to see stuff like this in pctures to understand exactly how its done!
Old 22-12-2006, 05:42 PM
CozzyKing
CozzyKing's Avatar
crikey thats had a wee bit of work done on it.
Should be a right load of fun so long as it stays together mate.
Old 22-12-2006, 07:14 PM
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
Old 23-12-2006, 10:43 AM
NUTS RuS
NUTS RuS's Avatar
Thanks for the update
Old 23-12-2006, 11:17 AM
AustenW
AustenW's Avatar
716 hp
http://www.qedpower.com/
Old 23-12-2006, 11:54 AM
Dan
Dan's Avatar
Love it MArtin, looks much better all yellow!
Old 04-01-2007, 05:21 PM
AdamB
AdamB's Avatar
dude, is your inbox full? i've had a message waiting in my outbox for you for ages now
Old 04-01-2007, 05:57 PM
ram
Has a large member
ram's Avatar
good to see a serious rover, top work
Quick Reply: Audi 20v Turbo powered Rover 25 (some new pics page 3)
