Capri Cosworth 24v Turbo
Hi everybody!
Thought I would share some pic of my projekt. Iv been runing the car with standard 24v Cossie lump for 8 years but now its going to get a Borg Warner Turbo re-make
This is as fore as Iv comed and I will update more when Iv made more progress!
Jepp, singel turbo it is!
@ 1bar and with octan booster to compensate the 9.7.1 comp. it should end up around 450 hp.
Just by geting a freeflow manifold/ intake and porting the heads gives a around 50hp increes! And 200hp gain with that turbo is no problem
Spank you everybody!
Fulesystem is a Bosh 044 pump, 3/8" inch braided hoses al the way with hydraulic cuplings. Standard fuleraila and 540cc injectros.
If ur going for N/A tuning this is the shit my friends!
http://www.dtafast.co.uk/Throttle%20...our_engine.htm website
This alone will easyliy give 35-40 hp.. with headers, porterd and polish heads and better cams; The shit will hit the fan!
This engein has massive potensial! We ported the heads 10mm!! Cosworth were doing everyting for keeping the power down..
And som more pics of how ur suposed to ues a Capri
Turbocharging Technician
Those ITBs look expensive! i would rather throw my money at a turbo than those! bet they sound good full chat though! Are you going to fabricate a manifold from stainless steel to match up with your turbo and exhaust ports? just i saw you have cleaned up the standard manifolds in your re-build pics
Nja, 42mm regular steel and wrap it.
When I started the re-bulid i was just gonna clean it up and fix the cain but the it got out of hand...hehe.. So thats why the manifolds were painted.
As all these projekts do! Im doing 24v turbo myself, using cast manifolds, then joining them together with steel tubing what are the specs of your turbo?
Borg Warner S200R
Comp.Wheel O.D: 3,14
Comp.Wheel inducer Dia: 56mm
Turbine Wheel OD 2,92
Turbine Wheel Exducer 65mm
Turbine A/R ,85
Think this will be a good turbo for the 24v.. The goal isent to max power but get a car that will be driveible but still scare the shit out of you!
Turbine A/R ,85
A clip from a few years back doing som 0-60 testing. 6,11 sec
http://www.youtube.com/watch?v=p059xTOyP4w
cool video mate, sounds awsome
Borg Warner S200R
Turbine A/R ,85
Turbine A/R ,85
very nice indeed
never seen the innards of the standard BOA plenum. can see why they are restrictive now
what power you expecteing from it? and any pics of what the new inlet manifold will look like?
these are what you want slide throttles from the fbe cosworth 24v
and this is what it sounds like
http://www.youtube.com/watch?v=YDh_rywjt0U
Trumpets
I have the slide throttle but want these trumpets instead of the long carbon one's.
Have you bought them or made them?
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
