Other Marques Use this section for any non Ford marques.
Can't find 'dipped' beam on my Capri
Old 05-11-2010, 06:03 AM
P37Mac
P37Mac's Avatar
Default Can't find 'dipped' beam on my Capri
Hi, my Capri only has two light settings on the stalk; Lowest setting does sidelights (both outer lights dim, rears on) and the only other setting seems to be full beam (both outer lights bright, both inners brightest, rears on, blue warning light on dash). Is this right? Tryed pushing and pulling the stalk every which way but I can't find a 'dipped' setting. Any help would be appreciated. Thanks.
Old 05-11-2010, 06:44 AM
Assuming this isn't a wind up, the small stalk you refer to is the main lighting stalk, it does NOT select dip or main, this is done by the full length stalk on the left that also does the indicators, ie push away is main beam and pull back is dip, pulling back against the sprung stop is flash(main beam).
Old 05-11-2010, 09:51 AM
P37Mac
P37Mac's Avatar
Cheers tabetha, tried all the stalks anyway (including the horizontal movement on the indicator). All the logos have worn off the stalks so I was hoping that I was missing something. Looks like I've got some work to do on the dip selecter then. Cheers again, at least I know where to look now!
Old 05-11-2010, 10:02 AM
1.9 xr2 on 40's
st170 breaking
1.9 xr2 on 40's's Avatar
could be busted i spose
Old 06-11-2010, 03:03 PM
evil knievel
evil knievel's Avatar
With stalk pulled into centre position (ie not pushed forward) once up is sides, twice up is dipped and pushed forward and twice up is main.
STAFFY OWNER
13-09-2015 08:59 PM
Maxwell
Fiesta ST
13-09-2015 05:31 PM
little bram
10-09-2015 10:45 PM
3doorcozmess
07-09-2015 01:32 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Can't find 'dipped' beam on my Capri
