Gauges, most important?
Old 02-09-2015, 07:00 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Default Gauges, most important?
With the Lolvo project moving along nicely, I'm turning my attention to the inside, namely where to mount the gauges as "Q car" is key here, so no A pillar or dash mounted pods! So we're having to get creative, but it also means room is an issue in terms of how many we can fit.
Other than a boost and wideband, what else would you recommend to keep an eye on things? Oil pressure/temp?
Ben.
Old 02-09-2015, 07:25 PM
Boost,air/fuel and voltage.
Cos500
Cos500's Avatar
Oil pressure for sure, I've got that plus oil temp and boost
Old 02-09-2015, 07:40 PM
gcfcos
gcfcos's Avatar
Oil pressure, fuel/air, boost and I've wired up a separate voltage gauge to my fuel pump wiring so I can always check what voltage there is on boost, very handy on a Cossie!
Old 02-09-2015, 08:11 PM
Sierrasideways
Sierrasideways's Avatar
This plus wideband
Old 02-09-2015, 08:15 PM
Cos500
Cos500's Avatar
Originally Posted by Sierrasideways
This plus wideband
Didn't you sell those?
Old 02-09-2015, 08:37 PM
simsytall
series 1
simsytall's Avatar
Oil temp,afr,boost
Old 02-09-2015, 08:52 PM
Sierrasideways
I sold my spare set mate. These are on my car at the moment and will only leave when they break which knowing my luck shouldn't be too long lol
Philip.
Old 02-09-2015, 09:00 PM
Cos500
Cos500's Avatar
Philip.
Sold em to me haha, they do look good although car still not finished
Old 02-09-2015, 09:18 PM
Sierrasideways
O ya I knew your username rang a bell
Keep up the good work mate
I'm nearly there....beam, brakes and wheels....only 5 grand ffs
Philip.
Old 03-09-2015, 07:48 AM
fraser9764
fraser9764's Avatar
Oil Pressure, Oil Temp, AFR and Boost.
Then a SECS monitor or similar ECU interface so you can check coolant temp, Air inlet temp, TPS Calibration etc.
Old 03-09-2015, 07:54 AM
haz87
haz87's Avatar
Oil pressure, voltage and AFR IMO
Old 03-09-2015, 11:03 AM
stevieturbo
C**t
stevieturbo's Avatar
If you want discreet, then get a multi function display.
Whether round or square type of dash.
PLX Devices do some nice round multifunction gauges, where one gauge can do pretty much anything, albeit you need separate control modules.
Old 03-09-2015, 12:18 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
That's actually a cracking idea, good shout! Never looked into them though, what are the control modules for?
Old 03-09-2015, 12:21 PM
stevieturbo
C**t
Each sensor requires a control module which then sends info to the gauge.
Or if the ecu in the car is OBD compliant, you can get it to display the data that way
http://www.plxdevices.com/category-s/109.htm
https://www.youtube.com/user/PLXDevices
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
IainRS1700T
25-09-2015 06:44 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
Quick Reply: Gauges, most important?
