Is it worth.......
Old 24-08-2015, 04:55 PM
cameron2
cameron2's Avatar
Default Is it worth.......
Changing the water pump at the same time as the cam belt on YB?
The reason I ask is that nobody has tried to flog me one on previous belt changes...... seems odd.
Old 24-08-2015, 05:53 PM
gcfcos
gcfcos's Avatar
It's not run off the cambelt so no need
Old 24-08-2015, 06:46 PM
cameron2
cameron2's Avatar
What drives the water pump then? An auxillary belt?
Old 24-08-2015, 07:12 PM
Yeh the 2 belts the go from the crank to the alternator to the water pump and back to the crack. Or less you run a poly v belt.
4x4 water pumps are a fortune.
Old 24-08-2015, 07:17 PM
cameron2
cameron2's Avatar
Cheers Glenn. Ive seen them on euro car parts for £21 reduced from £85.
Old 24-08-2015, 08:03 PM
Is yours a 4x4. I got one that was listed as a escort cossie and it was a 2wd cossie pump which is the same as a standard pinto.
I paid 105 quid for mine from msd.
Old 24-08-2015, 08:07 PM
cameron2
cameron2's Avatar
Yeh, mines a 4x4. The pump has never been changed according to the service history, is it worth changing with the cam belt?
Old 24-08-2015, 08:48 PM
Adam-M
Adam-M's Avatar
Check the condition of it, tbh I would anyway due to the age of it as it won't need changing again for a while
Old 25-08-2015, 07:15 AM
cossynut2
cossynut2's Avatar
A water pump isnt a set mileage or set time automatically change item, if it is working ok with no bearing noise there is no need to change it. I have had my 2wd for 21 years and it would have been costly to change the water pump every time I have had a new cam belt.
I think you are being over cautious but at the end of the day its your car so its up to you.
Old 25-08-2015, 07:18 AM
gcfcos
gcfcos's Avatar
I don't think there the right ones, there bloody expensive to buy for the 4x4, I managed to get a second hand one that had done 300 miles but still had to fork out £50 including postage. If it's not leaking or bearings noisy/play then I'd leave it well alone. Obviously up to u at the end of the day matey its your car. My one did 64,000 miles before it needed changing lol
