Mk4 golf tdi help?
Old 05-08-2015, 11:07 PM
xr_craig
xr_craig's Avatar
Default Mk4 golf tdi help?
My 1998 1.9tdi's battery light came on earlier today and the car then wouldn't start. I had a look and one of the fuses in the box on top of the battery had melted. I've bypassed this and the car started but it's still not charging. Any ideas what to check? Belt seems fine so I'm almost certain it's electrical but I'm not sure where to start looking.
Any ideas chaps?
Old 06-08-2015, 06:15 AM
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
Best thing to do m8 is change the fuse and test the load coming off the alternator
Old 06-08-2015, 07:08 AM
xr_craig
xr_craig's Avatar
Fuse has been temporarily removed so that's no issue now. I'll test that later on. Any other ideas for obvious faults? I'm praying for an easy fix as I'm away from home
Old 06-08-2015, 12:37 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Have a look down in front of the gearbox by the starter motor. There may be a 2 pin plug there on a plastic bracket on top of the starter motor. Sometimes one or both of the wires can break which will result in the alternator not charging. Not all of them have this plug though depending on the year (I can't remember what year has what).
Worth a look as I've come across this issue a fair few times.
Old 06-08-2015, 04:06 PM
xr_craig
xr_craig's Avatar
Checked for that and they both seem fine. I've come to the conclusion the alternator is definitely fucked
Old 06-08-2015, 11:31 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
If the clutch plays up the alternator shuts down.
Could just need pulley changing. £40 for the pulley.
Could be a buggered alternator though.
Old 07-08-2015, 03:03 AM
gcfcos
gcfcos's Avatar
Have u checked the charge rate with a multimeter?
Old 07-08-2015, 10:57 AM
xr_craig
xr_craig's Avatar
Someone else mentioned that too. Once I get the car home I'll have a proper look as it's going to need to come to bits anyway.
I've checked the charge rate and it's very low. So if it isn't the pulley then I'll change the alternator
Cheers chaps
Old 07-08-2015, 03:55 PM
jameswrx
jameswrx's Avatar
Have you checked the rest of the main connections in the box by the battery? I've done a couple of vag cars where the connections have burnt out. I've been out more than once to 'replace an alternator' and found the wiring connectors to the large fuses burnt out. Removed them and cleaned all the contacts and been fine after.
Old 07-08-2015, 06:00 PM
RichieST
RichieST's Avatar
A melted fuse is a sign of a poor connection at the fuse holder, giving a higher resistance, thus heat. If it was pulling too much current it would have simply blown.
AJC
01-10-2015 06:47 PM
SMILER258
28-09-2015 09:04 AM
Mr S1
20
27-09-2015 04:06 PM
streetracer
24-09-2015 08:14 PM
jc1989rs
18-09-2015 07:05 PM
Quick Reply: Mk4 golf tdi help?
