Mocking up brackets and stuff for fabrication?
Under the car...!
So, my kit car project has got pretty deep of late...
I am needing to make or get made various brackets and mounts and stuff.
I can weld to a decent standard, however I don't have any access to a machine shop for fabricating brackets etc so I am a bit stuck...
Option one is to make some templates and take them to a machining shop for them to copy. if so can anyone advise what materials would be easiest to use?
Option 2 is to buy a sheet metal bender and cut and make my own, but this involves quite a lot of cost and hassle
Option 3 - Is there anyone on here near South Yorkshire that does this kind of thing for a living??
I cant take the car to a shop as there's so much to do it would bankrupt me and give them a breakdown...
I make all my brackets out of cardboard and take them to Jim at alloy racing fabrications I Ollerton and he makes them for me. His fabricating skills are the best I've seen. His welding skills are beyond reproach
I've used mdf to mock up Caliper to strut interface brackets.
Under the car...!
thanks to other posters too. I want to use a machine shop to actually fabricate them if I can to save tim.e
I used thick mounting cardboard. I stick them with cello tape if needed and write the dimensions on each edge so he doesn't have to waste time measuring. I take pictures too of it in situ so he has a complete vision of what I need. Often he will suggest a better way of doing things
zetecbeast (21-05-2015)
Under the car...!
I think I will do that then
Under the car...!
07-10-2015 12:56 PM
