2003 1.4 petrol fiesta, starting probs
Old 22-12-2014, 01:59 PM
andrewmctiernan
andrewmctiernan's Avatar
Default 2003 1.4 petrol fiesta, starting probs
Hi all,
posting for a pal, 2003 fiesta 1.4 petrol is turning and not firing, he'd ran the fuel right down so I suggested sticking a few quid in and taking for a run, we bumped it to start it, it ran fine and started ok and was left overnight where it again failed to fire, we bumped it and it started, I have suggested sticking a new fuel filter on, it is not throwing any engine lights on, am i missing something, he had previously topped his engine oil but I think this will have no bearing
thanks
Andy
Old 22-12-2014, 02:28 PM
galingong
galingong's Avatar
You should determine if it's fuel or spark related. Checking spark would be the first thing I did - when it fails to start I'd remove spark plugs one by one, put them near the chassis or any grounded surface and you should see if you have spark or not.
I guess you should have fuel if it starts by bumping it. I had something similar with my previous car, it was an uncertain loom connector in the engine bay.
Old 22-12-2014, 02:41 PM
andrewmctiernan
it starts fine after the initial bump
Old 22-12-2014, 03:02 PM
galingong
galingong's Avatar
I understand that. Nevertheless you should check if you have spark or not.
Not likely, but possible that starter motor draws current and no current is left for ignition.
As I've said, very unlikely and still wouldn't explain why it starts later on, but all I'm saying is that it's worth checking. Maybe battery is weak, and after first start alternator charges enough for normal operation.
Old 22-12-2014, 03:16 PM
andrewmctiernan
battery is holding full charge at 12.7
Old 22-12-2014, 03:54 PM
andrewmctiernan
any chance its the fuel pump?
Old 22-12-2014, 04:20 PM
galingong
galingong's Avatar
May be, but you don't know until you check. That's why I said that if you determine if it's fuel or spark, then you have a starting point where to go next.
Old 22-12-2014, 05:57 PM
RichieST
RichieST's Avatar
What's the voltage at the battery while cranking?
Old 22-12-2014, 06:12 PM
andrewmctiernan
never got to that stage, swopped the fuel filter over, stuck a tenners worth of juice in and it was ok on my last test, no issues with the car till it was ran down to virtually zero fuel so I am hoping that may be it, could it be?
j4m3s46
28-08-2015 08:26 PM
loughlin1
Ford Fiesta
20-08-2015 10:42 PM
tommylommykins
Ford Fiesta
08-08-2015 08:01 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: 2003 1.4 petrol fiesta, starting probs
