| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| General Car Related Discussion. To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Sponsored by Cartown |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
Wye Valley Hardcore
__________________
![]() "BRAVERY IS THE CAPACITY TO PERFORM PROPERLY EVEN WHEN SCARED HALF TO DEATH"
#2 |
V6 Ka of Love
Don't know about the fuel pump selection but to calculate the swirl pot size you need to know the injector cc/min at the base fuel pressure you're running, the amount of boost you run and the time you wish to protect yourself against surge, I've used this post on Scoobynet to calculate what I needed....
or stick a 2 litre in one and not worry about it again lol
__________________
#3 |
big floppy donkey dick
Trader Score: (0)
Location: Building My High Reving 2.2 5cyl 20v Turbo powered RWD A4
Rep Power: 14 ![]() |
Totaly overkill,
my little brothers mk3 with 300bhp Zetec turbo on 803`s EASILY runs with no need of greys, at all! underbody tank with standard XR/RS fuel pump top feeding a boot mounted swirl pot, this in turn can graviry feed a 044 (gpA) Bosch pump, these can fuel easily 500bhp on many different applications (not shit ebay jobbie though) then choose your feed lines to the fuel rail -8 is normaly choice of use fuel rail pressure is normally 4 to 5 BAR
__________________
Couple of Quick Audis and RouseSport Saff
#4 |
Bodger of Blackburn
i run a zetec turbo and get injector duty to 86% on 630cc siemens.
i run a 979 fuel pump fed from a 1 litre swirl pot fed from a single red top facet interrupter lift pump. i haven't had any issues with fuelling at all. |
#5 |
return the rail to the swirl pot then swirl pot back to tank
__________________
jamsport built 1600cvh, gt30 ,roller rockers mtx ,12.7@122mph |
#6 |
Bodger of Blackburn
as above too, missed that bit in original thread, always return to swirl pot, otherwise you could easily end up emptying the swirl pot.
#7 | |
Quote:
And returning to the swirl pot results in hotter fuel. There is no reason a properly designed setup cannot return all fuel to the main tank. Although the easy option is returning to the swirl tank. Although surely if this car is a race car spec of any kind with a custom fuel tank there cant be a need for any external swirl tank ? Isnt that part of the reason you'd design a custom fuel tank in the first place ?
__________________
speed didn't kill me, but taxation probably will. Only state in the world where you try and work hard and the government will slaughter you. 9.85 @ 145mph 202mph standing mile http://www.youtube.com/watch?v=XgWRCDtiTQ0 |
#8 | |
Quote:
__________________
![]() 0-60 in 5.03 and winner of the fwd sprints at ford fair 2009 and 2010. 1/4mile in 12.7@ 123mph |
#9 |
Trader Score: (0)
i agree
***after reading origional post again, i thaught it was a zetec turbo My bad
__________________
#10 | |
Quote:
Whats your opinion on that ? is overheating the fuel that much of an issue ? |
#11 | |
Bodger of Blackburn
Quote:
the reason for the return to pot is the fuel not needed from the rail isn't dumped into the tank just to be pumped up again (which also heats the fuel in the tank like all other systems). an engine rarely requires max fuel all the time, so you can spec the lift pump below the max needed, but better to go higher really. consider a facet red top interrupter flows 37GPH, so 166LPH, 600cc injectors x4 flow 144LPH. so a facet will flow enough at max flow for four 600cc injectors just fine. |
#12 |
Trader Score: (0)
cc/min depends what pressure is held at the rail though
__________________
#13 | |
Quote:
So if the rails/engine bay is a very hot environment, then it is possible for fuel to get very hot. As to how much of a problem this might be I dont know, or how hot it would actually get. But it could get pretty hot. But the simple reason people plumb it this way, is so they can get away with a much smaller lift pump. If you use an adequate lift pump, then there is no reason at all to need to return any fuel back to the swirl tank. This also ensures no hot fuel at all is ever re-circulated into the small swirl tank. It's just a simple design matter. As far as temps go, Ive only ever monitored my own but I just run a large fuel tank, no swirl. But I have seen as high as about 38degC on a warm day with the engine running. ( do have a cooler on the return line, although it's very badly placed. But probably does help a little. So I'm sure with a small swirl tank temps could easily get pretty hot. Although if you do return to the swirl tank and also use a decent lift pump, it may have sufficient volume of flow to dilute the hot fuel from the engine enough that heat in the swirl tank doesnt become an issue return to swirl tank = lift pump only has to flow enough fuel that the engine is actually consuming. return to main tank = lift pump has to outflow the main engine pump at all times It's very simple really.
__________________
#14 | |
Quote:
Regarding a swirl pot I always believed the very top fitting was return to the tank and the next one down was a feed from tank or return from rail, but Dale has plumbed his slightly diferently.
__________________
Tim ![]() For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys. For all your stickers ~ Email stickerpaul@yahoo.co.uk |
#15 | |
Quote:
Yes it was Dales car, was a odd one really as I've never known anyone to do it differently! I think his return from the engine was going in the top or it's the feed from the lift pump, a bit odd but he is only going off what he has been told to do. |
#16 |
The very top fitting on the top of the swirl tank is always the return to the main tank. If it's plumbed any other way it's wrong.
__________________
#17 | |
Wye Valley Hardcore
Quote:
As you said though, I wanted to return the fuel to the tank to prevent over heating that's why I wanted to know if I needed twin lift pumps to keep the pot full. I think for peice of mind, I'll run a pair of Facet red tops and see how I get on. Not sure why I'm bothered about how noisy they are when I have a straight cut box and a stripped interior
__________________
#18 |
Bodger of Blackburn
top feed from swirl pot is always to tank, this is to stop pressure build up and rid of any air in the system.
with a sufficient lift pump i would agree that there would be a decent flow back to tank, so i see no issue with retuning from fuel rail to swirl pot. i did run a test after idling for abot half an hour and temps did rise a little to be fair, just over 30 degrees. with the inlet being warm and fuel rail itself getting hot due to heat soak i didn't think there would be much of an effect doing it differently. more to the point you'd have to make sure your lift pump is bigger than the injection pump, as in flows more. more importantly if there is fuel surge in the tank for a few seconds, then the lift pump won't be filling the swirl pot, but the injection pump will be draining it quickly. best thing is to try it different ways and see how it works best for your requirements. |
#19 |
Bodger of Blackburn
p.s. facets aren't that noisy lol!
you can live with them especially on a track car. i have both my pumps in the boot, but it's not stripped out though. |
#20 | |
Quote:
Will a Facet flow more than the Bosch pump ? What is the main engine pump you intend to use ?
__________________
#21 |
Bodger of Blackburn
ERST pump flows about 130LPH IIRC
#22 |
At efi pressure or open load ? Not that great really.
__________________
#23 |
#24 | |
Quote:
I also thought having the fuel going on on the side is supposed to help de-air the fuel??
__________________
#25 | |
Quote:
__________________
#26 |
![]() There you go, a pic of Dales setup. Can clearly see the feed from the tank goes to a filter to the very top of the swirlpot.
__________________
#27 |
Bodger of Blackburn
is that not possibly a filter on the return and no filter on the feed from the in tank pump?
odd setup if it isn't though. |
#28 |
YES I KNOW I CANT SPELL
i run a redtop lift pump lifting from my tank into my 1 leater swirl pot and my 044 feeds from the pot and feeds a set of 650cc injectors and its been fine on my 415hp zetec turbo
__________________
" im special,, excuse my spellings" |
#29 | |
Quote:
#30 |
What an incredibly weird and wrong way to plumb the entire system.
__________________
#31 |
Wye Valley Hardcore
Cheers, guys, I think I have all the info I need.
__________________
| Display Modes | |
