camshaft timing.....
i have just replaced my damaged bd14 inlet with another brand new bd14 inlet,my exhaust cam is standard.Now im gonna have a go at dialing them into what it reccomends in the KENT book and see how it goes,is this the way everyone does it or is it a case of finding the best settings for the engine.
I have ported head,T38 etc etc running 30+psi.
Ta much
Ta much
Proven Legendary Status
I cant say for your specific engine. But Ive always been told the following for dialing a cam in. And Ive never been told in terms of mm's only ever angles.
1) Find ABSOLUTE TDC. Use a DTI gauge down the spark plug hole. The marks on the block may be a fraction out due to manufacturing tolerances.
2) Put the printed protractor on the crank. And working from TDC turn the crank to the set angle that cam manufacturer recommends. Normally somehting between 90 an 115 degrees
3) Turn the camshaft and using a run out gauge get it to absolute maximum lift (that should be the middle if the lobe)
4) Bung the belt on. And make sure nothing has moved. If it has then use the movement in the vernier pulley to get back to those "perfect" settings.
5) Turn the engine over BY HAND (by turning the CRANK not the CAM) a couple of times and recheck the settings.
If thats wrong I'd love to know the other way
Rich_w
i never turn a crank or cam over without having a belt fitted!
Originally Posted by GARETH T
Rich_w
dont be so scared
Originally Posted by Stu @ M Developments
Originally Posted by Baldy Butch
ring Stu at MSD he will help you out he did it last time
PassionFords Creator
Originally Posted by radiant red
it was something llike 2.2mm at TDC
The worry here, for me, is that you are doing this on a pretty high comp YB with a Turbo Technics T38, big ported head and about 8.5:1 compression ratio and i know for a fact that if you get it wrong its going to melt like a mars bar in a furnace as that motor was pretty flat out when i finished mapping it and the map and fuelling didnt have much room left in it for you to start moving its peak VE point around, as you will if you get the timing wrong.
If you wish to proceed, i will PM you the peak lift figures when i am at work, as i wil have made a note in the maps, but i will need you to send me the serial number from teh chip first please.
"Cam timing worries...."
How come once the cams are dialled in, all 4 inlet and exhaust valves open and close together? Wouldnt that mean all the gas escaped?
If you wish to proceed, i will PM you the peak lift figures when i am at work, as i wil have made a note in the maps, but i will need you to send me the serial number from the chip first please.
i am reffering to the method given in the kent handbook as supplied by burton on purchase of a cam.
Method 2 in the book is the way we all know and do and the other way is much easier although im sure there must be flaws....
1.Set engine to TDC on no1 cylinder
2.position a clock gauge on the inlet follower and turn the cam to achive the specific lift (i.e 2.72mm)
For a bd14 they recomend 0.66mm (god knows where i got 2mm from)
Rich_w
Rich_w
im always very careful as a slight slip of the mind,, and you have fucked your valves
why not set them as you fit them? how can you set them to standard ford settings, as you wont be using the standard ford timing marks, ie the cam pulleys
i was just gonna put the standard cam pullys on, mark the cams, take the pullys off & fit the verniers & check the cams havent moved from the marks i make. then just fit the belt as normal & get the mapper to adjust the verniers. i dont know how to set cams up with a dial gauge or what the setting should be for my engine/cams
foreigneRS
Technical essay Archives
20-07-2004 11:29 AM
foreigneRS
20-07-2004 11:06 AM
