Water injection
Water injection
Hi all,
Is any 1 running water / methanol injection? If so what system have you got?
A friend of mine is running water injection and told me its just off a conventional washer pump and bottle but is using a control box that see's boost pressure and obviously comes in at low boost then shuts off at high boost.
Ive had a bit of a look online and see AEM do a kit and DEVILSOWN do a kit but both are a bit pricy if its only a washer pump bein used.
I looked at some DIY versions and seen that the only specialist parts are the nozzle and the controller unit.
Does any 1 know where the controller units can be bought from or can they be made also?
Thanks
Thanks
John Caine (22-05-2021)
Happily retired
I use a aquamist pump controlled by my Emtron ECU. 50/50 water/Methanol mix. Its got nothing to do with Boost its required only when Charge Air temps go above 40 deg C.
abdr500
23
18-06-2005 05:49 PM
avengerpenguin
07-09-2004 08:43 AM
