long stud kit help!!!!
Old 11-04-2016, 09:27 AM
lee954
lee954's Avatar
Default long stud kit help!!!!
hi everyone just bought a saff cosworth with head gasket gone but cannot get head off due to being fitted with long stud kit but the holes in the head have not been machined out so cant get a socket in th the nuts! i have had two sockets turned down on a lathe but both have broken when trying to undo the nuts?? anyone got any ideas please???? thanks
Old 11-04-2016, 10:32 AM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
When I took my head off my engine I borrowed a ground down socket off a mate. There was very little room
Old 11-04-2016, 12:28 PM
costina
Live long and prosper!!
costina's Avatar
What block? Hope its not arp kit.
Could try turning down a inpact socket.
Old 11-04-2016, 05:10 PM
Ridgey
Ridgey's Avatar
I've used a turned down socket without issues.
You really need to have the socket turned down so it only just fits in, keep as much meat on it as possible.
Old 11-04-2016, 05:38 PM
lee954
lee954's Avatar
it's a 200 block and i have measured the holes at about 23mm. not sure what kit it is as was already on when i bought the car. i looked on some other posts here and most are saying 18mm nut sure my one is 19mm do they do different sizes?
Old 11-04-2016, 06:23 PM
jamie956
jamie956's Avatar
My mates just been through this the newer long stud kits are now using a bigger nut (19mm i think) and you really need to machine the head out, only way to get off is to keep trying with the machined down sockets.
Try machining down a multi point socket not a 6 side.
Old 12-04-2016, 08:18 AM
lee954
lee954's Avatar
ok thanks! looks like it is going to be a case of just keep trying just hope they will come loose otherwise not sure what i can do!!!
Old 20-04-2016, 06:33 PM
mattman1234
mattman1234's Avatar
same here,ground down a socket
Old 12-05-2016, 04:41 PM
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
julian godfrey sells smaller nuts which fit without any socket machining
Old 12-05-2016, 05:04 PM
Caddyshack
Caddyshack's Avatar
Lol, at least we know what the previous owner should have fitted.
Good to know for putting it back together though
wayne1001
09-07-2016 01:19 PM
turbotrev
15-04-2016 07:02 PM
steppy
10-04-2016 03:55 PM
mondeomark
09-04-2016 07:50 PM
jamie956
08-04-2016 09:45 PM
Quick Reply: long stud kit help!!!!
