Max boost-bhp T36 Siemens 55's
Old 04-03-2016, 08:45 PM
-=Cossie=-
-=Cossie=-'s Avatar
Default Max boost-bhp T36 Siemens 55's
Hi All,
Bit of advice needed.
I have just got a new TT T36.63 from tony at TurboSystems, (thanks tony ) to replace my broken T34.63, anyone know what safe boost-bhp i can run with siemens 55's?
i have Ab07 inlet cam and standard head.
Old 05-03-2016, 03:43 AM
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
id say speak to tony@turbosystems as hes supplied it to you and he knows these turbos inside out
Old 05-03-2016, 06:40 AM
-=Cossie=-
-=Cossie=-'s Avatar
Didn't think of that lol
Will do..
Old 05-03-2016, 12:11 PM
dissmalrs
dissmalrs's Avatar
mine is running 55lbs and a t34.63 at 32psi
it made 402bhp (if you believe the dyno)
standard cams and bottom end wrc head gasket been like that for 3 years with no drama but i think the turbo runs out of puff at the top end
Old 05-03-2016, 12:34 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
I'd ask Tony as well lol
Old 05-03-2016, 01:25 PM
bluntys1rsturbo
Boost addict
Will do..
haha
Old 05-03-2016, 04:37 PM
-=Cossie=-
-=Cossie=-'s Avatar
dissmarls thats the setup i had until the t34 dropped a turbine blade, anyway i'm a bit slow atm having spent the last week trying to remove a snapped exhaust stud with head in situ which i have finally done.
So..
Tony with your infinite wisdom could you give me a rough idea of a safe boost limit with the T36 and siemens 55's, AB07 cam, standard head, 7.8 cr please lol
Much appreciated.
Old 05-03-2016, 07:38 PM
costina
Live long and prosper!!
costina's Avatar
55lbs run out of puff at 420bhp sounds like you need 83lbs.
Mine is on the limit at 421bhp at 2.3bar peak on a 34/48 with a afr of 12.5 on a standard engine.
Best get Tony to sort you out.
Old 05-03-2016, 07:43 PM
Jay,
Sponsor
Jay,'s Avatar
Well I had the same spec and Tony told me 2.2 bar so I thought about that for at least 30 seconds and then run 2.6 bar with 1,9 held and I trhink you will find its a tt36.55 and on a standard head it will surge a tad at low rpm in 4th and 5th but overall a very good replacement over a t34
Regards Jay
Old 05-03-2016, 08:48 PM
-=Cossie=-
-=Cossie=-'s Avatar
Thanks for the replies everyone, Jay i got confused when tony said that i need a .63 i thought it was exhaust housing for 440bhp lol, on the TT card that i got it says .63 A/R and part S241 so i guess that must be the compressor housing then, didn't know a smaller housing could make that much power, cheers for the info.
Tony can you clarify that i have a .55 exhaust housing because i think i might have screwed up when i sent my old chip back for a new one...
Old 06-03-2016, 05:52 PM
Adam-M
Adam-M's Avatar
Bet that fucking flies!! Is it a saff 2wd you have? What headgasket and bolts you using to cope with that much pressure?
I didn't think it was possible for a t34.48 to produce that amount of power
Old 06-03-2016, 06:05 PM
costina
costina's Avatar
No I didn't think it was possible either.
Engine is standard only a Group A gasket and standard bolts just as cosworth intended. Only difference is the turbo has cutback blades which makes for a little more lag.
Dyno was a DD and they specialise in jap stuff and they where shocked too.
Search my posts and you will find the graph.
Old 08-03-2016, 05:49 PM
Adam-M
Adam-M's Avatar
Didn't know 55's ran out of puff at 420bhp mate, would 83's run ok on a msd mapped 400bhp car? Future proofs mines then instead of swapping when I want to up the power.
I thought 55lbs where an alternative for Bosch greys but apparently they're good for 450bhp
Old 08-03-2016, 08:48 PM
Jay,
Sponsor
Jay,'s Avatar
Never seen 55s run out at 420 bhp as there bigger than greys they will do more
Old 08-03-2016, 08:59 PM
Turbosystems
Super Moderator
What's that terrible smell can anyone else smell it
Old 08-03-2016, 11:31 PM
Jay,
Sponsor
Jay,'s Avatar
Yeh lots of fuel if they are maxed out at 420 bhp lol
Old 09-03-2016, 05:17 AM
costina
costina's Avatar
Ah the penny has dropped that would be why Stu said he could tweek the map for more fuel.
So on that respect i guess 55lbs will do more around 440 bhp so i have been corrected sorry.
Tony if you smell bullshit you have a far better sense of smell than me
It might not last very long but who cares
Old 18-03-2018, 11:31 AM
Thanasis
Thanasis's Avatar
With what ecu?
Old 18-03-2018, 02:00 PM
costina
costina's Avatar
Originally Posted by Thanasis
With what ecu?
L8 MSD map wasted spark closed loop.
Old 18-03-2018, 04:11 PM
cossynut2
cossynut2's Avatar
Nothing wrong with that set-up.
Old 18-03-2018, 05:01 PM
Thanasis
Thanasis's Avatar
And with what bar boost?
Old 18-03-2018, 06:04 PM
costina
costina's Avatar
2.3 bar peak
please remember this is on a T34.48 which started life as a GrpA turbo with a 34mm restrictor. I then changed the front housing for a std escos one.
This turbo will produce more power than a std 34/48 due to cutback blades which is why I have a touch more lag.
when is was on the dyno it was pressirising the cooling system due to a failed head gasket.
I knew this before the dyno due to cylinder leakage test which showed 60% on number 3 cylinder.
I have since done the gasket and still feels strong.
Old 18-03-2018, 06:14 PM
Caddyshack
Caddyshack's Avatar
Could the head lift a bit on standard setup at 2.3 Bar? Mark originally thought mine was at 2.2 but I actually didn’t have the correct pressure relief on my expansion tank, it was fine after.
I don’t know how high boost we will go on the new stroker?
Old 18-03-2018, 06:54 PM
1374lee
1374lee's Avatar
2.3 bar peak
I have been in this car on full boost and it packs on hell of a punch for a t34 set up.A cracking road spec car, power which is low lag and useable in the right places of course.
Thanks. Lee.
Old 18-03-2018, 06:57 PM
1374lee
1374lee's Avatar
The t36, sounds very interesting, however there are many variations so I was told by one tuner, so be careful,go through Tony for sure.I remember when Jay had his and Big Steve (cossie4i) had these turbos a couple of years ago.
CheeRS.Lee.
Old 18-03-2018, 07:59 PM
costina
costina's Avatar
Yes Toby I guess it could but if you see the gasket that had been on there for about 14 years it was very corroded and breached between number 3 and water jacket.
Old 18-03-2018, 09:07 PM
Thanasis
Thanasis's Avatar
I don't know if the L8 can read 2.3 bar boost as the map sensor is 3bar ! maybe can explain the mappers.
Old 18-03-2018, 09:33 PM
costina
costina's Avatar
It cannot but Stu might be able to explain if he sees this.
All I know afr was around 12.5 which is really as lean as you can go imo. Stu did say he could add more fuel for top end to get it a little safer but it is only at that rpm for second's so I wasn't that bothered.
Old 18-03-2018, 09:35 PM
Adam-M
Adam-M's Avatar
I think they work out how much fuel is needed for 2bar and then just allow the ecu to keep adding the same amount until the rev limiter once the map sensor is maxed out. End up running rich at the top end for safety.
One of many benefits of going aftermarket ecu is you can use 4 bar map sensors, I’m going to be using a Bosch 4 bar map sensor on my next ecu and it will fit in place of my air temp sensor as the Bosch map sensor can read pressure and temperature
Old 18-03-2018, 10:32 PM
costina
costina's Avatar
The joys of aftermarket management.
if I had a bigger turbo I would not have to run soooooo much boost lol.
Old 24-03-2018, 08:39 AM
turbotrev
turbotrev's Avatar
You just change the map sensor, I run level 8 and a 5 bar map sensor.
You don’t need aftermarket management to do this
Cheers Paul
Old 24-03-2018, 10:50 AM
costina
costina's Avatar
Paul what map sensor? Bosch?
And I guess a remap would be required
Old 24-03-2018, 11:01 AM
costina
costina's Avatar
I should have looked at my old thread about map sensors.
Old 24-03-2018, 12:09 PM
smiley
smiley's Avatar
Lads what's a t35 apparently that's what's on my saph it's msd l8 closed loop wasted spark on 55's 32 psi
Old 24-03-2018, 12:15 PM
costina
costina's Avatar
T35 is usually a T34 / 63 with some extra mods.
A T36 is a 34 with with the compressor housing machined out from what I have read.
Old 24-03-2018, 12:20 PM
smiley
smiley's Avatar
Aha thanks for that mate
Old 24-03-2018, 08:03 PM
turbotrev
turbotrev's Avatar
It sure what make the sensor is tbh, my tuner fitted it.
Mine was in for re-mapping at the time of fitting it, just had some extra mods done for future tuning
Cheers Paul
Old 25-03-2018, 09:06 AM
costina
costina's Avatar
Cheers Paul
Could you take a pic please Paul? Who mapped it?
Old 25-03-2018, 09:52 AM
cossynut2
cossynut2's Avatar
T35 + greys is usually the first step up in performance and is a well tried and tested set up.
Old 25-03-2018, 11:20 AM
Loomer
Loomer's Avatar
You can do a 5 bar on the Weber, but my experience of it is that the ecu is very limited in resolution so they dont actually drive very well on it, there isnt enough breakpoints to spread that pressure scope.
Quick Reply: Max boost-bhp T36 Siemens 55's
