Should I go to a stage 2?
Old 07-01-2016, 07:33 PM
jc1989rs
jc1989rs's Avatar
Default Should I go to a stage 2?
Easy all
So my 2wd is running a stage 1 been running that about a year now but want a bit more! Is it worth going to a stage 2 or should I go straight to a stage 3? I want to keep the standard turbo that's the reason I'm thinking stage 2.
Then I've got the problem of a descent 3 bar map sensor, I've heard bad things about the brands hatch ones so what's options? Second hand Marelli ones are like rocking horse s**t and are crazy money when they do come up.
Thanks chaps!
Old 07-01-2016, 10:27 PM
Adam-M
Adam-M's Avatar
Id go straight to stage 3, your t3 will be fine at that upto 320bhp. Most genuine 3 bars are about £150, I've never used a BHP 3 bar nor seen a reputable tuner test one, I've seen his eBay add picture show him test them but they don't have any vacuum hoses attached so how can they be tested in the pic it doesn't make sense.
Take it your engines good?
Old 07-01-2016, 11:49 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Stick a t34 on it and a good intercooler and breather system they come alive at 350bhp. You can keep all the standard parts to one side
Old 08-01-2016, 02:22 AM
Sierrasideways
Sierrasideways's Avatar
What he says!
Old 08-01-2016, 09:09 PM
jc1989rs
jc1989rs's Avatar
Ok thanks chaps! Will look into a t34 any recommendations where to pick one up? Engines good recent full rebuild so should be able to take the power easily.
Old 08-01-2016, 09:35 PM
costina
Live long and prosper!!
costina's Avatar
You will need a T34.48 for a good punchy road car.
Could try a turbo specialist to convert your T3 to T34 spec.
I have seen 360bhp on greens with a T34.55 and green 803 inj on a mates car with a MSD chip. But thats on the limit.
Paul
jc1989rs (10-01-2016)
Old 08-01-2016, 09:43 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
Anything around the 350bhp mark is going to be good fun. Definitely go for the regular stage 3 conversion with a good map.
Old 08-01-2016, 10:22 PM
Staffi
Staffi's Avatar
My best fun Cossie was my old 3dr years ago on Greys, T34.48 NMS live map, only made 363 and 370ft/lb but man it was a HOOT on the road
Pete
Old 09-01-2016, 12:51 PM
martysmartie
martysmartie's Avatar
You will need to change the injectors and actuator as well, in addition to looking at the breather system.
An alternative is to look into a 'Gunship' conversion, with a standard engine, this will make slightly more power than you have, but with the torque of a stage 2.
Martin
Old 09-01-2016, 01:25 PM
costina
costina's Avatar
Pete
Mine done 421BHP and 418lb ft on the same turbo and 55lb.
with loads of boooost
Old 10-01-2016, 06:58 PM
Adam-M
Adam-M's Avatar
That would be awesome on a 2wd cossie.
Old 10-01-2016, 07:07 PM
costina
costina's Avatar
At 2.3bar it's a hoot
Old 10-01-2016, 08:03 PM
jc1989rs
jc1989rs's Avatar
Thanks for all the advice. I'm going to go for the stage 3, f**k it why not!! Lol could I replace the internals of my turbo with something like this? http://www.ebay.co.uk/ulk/itm/321502513790
Old 10-01-2016, 08:10 PM
costina
costina's Avatar
tbh it won't be much more to have yours done.
Old 11-01-2016, 10:33 AM
mickey2679
mickey2679's Avatar
Mine done 421BHP and 418lb ft on the same turbo and 55lb. with loads of boooost
418 with a t34.48 how long did the turbo last? What boost was that at? I've got the same set up and going nms in Feb/March for live mapping,
Old 11-01-2016, 12:14 PM
costina
costina's Avatar
Done about 3k on that turbo which is a cr turbo stg 2 with cutback blades hence the power but slighty more lag.
turbo is maxxed out at about 35psi peak and 28psi @5.5k.
Dynoed at Horsham developments who are a jap specialist on a DD dyno.
Full Msd chip.coilpack etc.
Old 11-01-2016, 12:19 PM
costina
costina's Avatar
Not bad for a std engine on 93k
Old 11-01-2016, 12:54 PM
jontysafe
jontysafe's Avatar
Nice one!
Old 11-01-2016, 01:00 PM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Easy all
Thanks chaps!
Speak to Matt Lewis regarding a MAP sensor mate as he has sorted out an alternative sensor, he tested one on my car last year and it worked fine 
jc1989rs (11-01-2016)
Old 11-01-2016, 02:41 PM
costina
costina's Avatar
That is good to know.
Old 11-01-2016, 02:42 PM
costina
costina's Avatar
Originally Posted by jontysafe
Nice one!
Don't forget when its dry i will take you out.
Old 13-01-2016, 07:54 AM
jontysafe
jontysafe's Avatar
Looking forward to it!
My engine build is well underway now. Bought Titan dry sump for it. Seeing engine builder Saturday to schedule everything as want back for summer.
Can feel my wallet weeping already.
Old 13-01-2016, 09:44 AM
cossynut2
cossynut2's Avatar
[QUOTE=costina;6649752]Don't forget when its dry i will take you out.[/
QUOTE]
You need a dry road with a big power 2wd thats for sure!
Old 13-01-2016, 12:20 PM
costina
costina's Avatar
Ouch
Old 13-01-2016, 12:21 PM
costina
costina's Avatar
[QUOTE=cossynut2;6650118]
QUOTE]
Oh yes i know from experience.
Old 13-01-2016, 03:12 PM
costina
costina's Avatar
grrr wrong section.
Old 13-01-2016, 03:25 PM
Staffi
Staffi's Avatar
Amazing power/ torque levels Paul for that Spec
Old 13-01-2016, 05:45 PM
costina
costina's Avatar
Yeah i know. I Asked Stu what i need to keep and eye on regarding temps etc.
Those guys asked what i thought it would be to which i replied anything over 350bhp but i have 400 lbft. First run resulted in wheelspin so it was tightened down more.
Then 421bhp happened and i asked is that correct 3 times while they was all looking amazed lol. And they are a jap tuner so no inflated figures for a ford taxi.
All i can say its good fun to drive.
Gary @ RS CLASSICS
12-03-2016 06:12 AM
3doorcozmess
12
15-02-2016 09:38 PM
jc1989rs
23-12-2015 11:05 AM
TrevCos
13-12-2015 03:46 PM
Quick Reply: Should I go to a stage 2?
