Wiring Diagram Request 4x4 Saph Cossie
Old 25-08-2015, 09:17 PM
DixieTheKid
Pick-up P100 Power!
DixieTheKid's Avatar
Default Wiring Diagram Request 4x4 Saph Cossie
Hi people. Does anyone have a car wiring diagram for a 4x4 saph cossie please. I've had a good look on line but unable to find out one. Thanks a lot.
Old 25-08-2015, 10:50 PM
kosienutter
Last Time, Get Off PF FFS
kosienutter's Avatar
Here's an ECU one. You after a whole car wiring loom??
Old 26-08-2015, 05:57 AM
DixieTheKid
Pick-up P100 Power!
Thank you but yes its the car diagram I am after.
Old 26-08-2015, 07:49 PM
kosienutter
Might be worth a look at these??
http://www.fordmanuals.org/page-1739.html
Old 27-08-2015, 08:26 AM
DixieTheKid
Pick-up P100 Power!
Yep sport on. Thank you
Old 27-08-2015, 04:00 PM
kosienutter
No problem
Old 30-08-2015, 08:32 PM
rdvil
rdvil's Avatar
Sharing is caring, if anyone needs more...for a 1992 model at least.
Dropbox linky
Air conditioning wiring is not directly applicable to either the DOHC or V6, as included in this one, but I can help with that if needed.
Old 23-07-2023, 10:16 AM
kamala
kamala's Avatar
For a quick on the compressor clutch, look in the engine fuse box for relay R6. remove the relay to show the 4 connections. Standing at the front of the car, the two leftmost connectors (horizontal) are permanent power and clutch. short with some wire and you can hear the clutch operate. Start the car and see if you get cold air. You can also put a bulb or meter across the other two to see if the relay is trying to operate.
jdsjojo
30-08-2015 07:48 PM
jdsjojo
26-08-2015 10:09 PM
lukeeboy149
22-08-2015 04:29 PM
cossie330
22-08-2015 12:00 PM
gcfcos
118
18-08-2015 05:53 PM
Quick Reply: Wiring Diagram Request 4x4 Saph Cossie
