Cosworth Coilover options??
hi guys im after some new suspension for my cosworth as i want to be able to adjust the ride high as it seems to be sitting low, its currently on Konis.
I have a budget of £500-600 and was after some advice or opinions??
Save some more money. £500-£600 won't get you quality items
Gaz are in your price range, Gaz golds are a little bit more! I got Gaz adjustables on, I paid £500 n can't fault em mate lot better than the koni' s I had on before
I have Konis atm but i want adjustablity, hence the Coilovers.
Harsh but fair.
Ultimately coil overs can do what ever you want them to do; damping, rebound, spring rate etc.
Unfortunately the budget end of the market tend to be less well resolved both in terms of performance across a spectrum of uses (road, track etc), and also despite looking great when new tend to deteriorate fairly quickly and not wear so well as better crafted (and more expensive) items.
Buy right, buy once (or words to that effect) but it will be comfortably double your budget.
That said, the good stuff retains it's value for that reason and is also eminently serviceable, so if you need to sell them on there's always a market for them.
Right now that looking for a used set could be an option for you? But if so, to limit more expenditure try to aim for stuff which has had a service, or calibration recently so you know they're still performing as they should.
Iain
Iain
Harsh but fair.
Iain
Iain
Very wise words. I work at leda, we see a lot of budget dampers brought to us for a check and dyno. Few if any match or give the spec required. Gaz seem to be getting a lot better these days, try and get a set of golds if you go that route. They have a better adjuster knob.
JoeyBoyden
04-01-2024 02:36 PM
jessie_rs
11
03-06-2019 04:57 PM
adam151082
30-08-2015 08:34 AM
adam151082
11-08-2015 04:50 PM
