3dr brake servo stopped working.
I've had a good push on all 3 connectors with the ignition on, still not getting the pump going.
Put a multimeter on the pump wires and I'm getting 12v, so I thought it was the pump.
Found an old servo removed the pump and plugged it in but still nothing.
Will it be the pump it self with having power? And the spare pump knackered?
Never know of pump packing up, be very unlucky to have 2 dud ones..
Are you sure the plug is making a good connection to the pumps?
Only things I know are poor connection and the fuse/relays under the dash on the drivers side but if you have power then it can't be those
I'll have another look at it again and give the connectors a clean up and see what happens
Iv not looked and this is only a theory but if your gettig 12v to the pump is it possible that it is switched on an earth.
And the pump is not getting switched on
Like a say I don't know how these are wired up as iv never looked but dose seem a bit unlikely that 2 pumps are dead
Cossikev
13-09-2015 02:00 PM
