Sapphire engine tear down & rebuild
Old 19-02-2015, 07:46 PM
jc1989rs
jc1989rs's Avatar
Default Sapphire engine tear down & rebuild
My cozzy's been burning oil on over run for a while now but last week (after doing the stage 1) cylinder 4 kept oiling up the spark plug as soon as you lifted off.
So the heads got to come off to see if its the valve guides or the piston rings! Oh the joys I just can't wait...
Hopefully it's the guides or stem oil seals, she's only done a genuine 52000miles but I guess we will see Monday when I take off the head. Will keep you guys posted
Old 19-02-2015, 07:58 PM
toutcos
toutcos's Avatar
On a lighter note the car looks stunning mate good luck
Old 19-02-2015, 08:12 PM
costina
Live long and prosper!!
costina's Avatar
check the outlet turbo to intercooler has no oil in it. Check inlet too.
Disconnect standard breather as this to pumps oil vapour into inlet.
Clean it all out and check before removing head.
Old 19-02-2015, 08:38 PM
The Crocodile Hunter
The Crocodile Hunter's Avatar
When mine did that a few years ago it was the seals in the turbo. Although it was never enough to oil up a plug
I did the head gasket last year and checked the guides whilst it was apart, they were well worn and i had them replaced. It never suffered from smoke on the over run because of this though?
Old 20-02-2015, 12:18 PM
costina
costina's Avatar
Over run creates vacuum so will drag any oil from the intake usually number 4 will suffer.
Old 23-02-2015, 06:41 PM
jc1989rs
jc1989rs's Avatar
Default Day 1
Cheers for all the advice guys, have checked the turbo and oil breather system all good there.
So day 1 is done and the heads off!
Have checked the guides and the stem seals and there all good, well a small amount of play from the guides, anyone know the tolerances for the valve guides? Have got a engineer coming to inspect the head tomorrow anyways but good to know.
There's no scoring of any of the cylinders so she's hasn't chewed through a ring, but still could be the ring seals so have filled up the cylinders and leaving her tonight to see if the fluid drops.
Will keep you posted!
Old 23-02-2015, 07:21 PM
Paul_RS
Paul_RS's Avatar
I see the problem - your pistons are made out of water!
Old 23-02-2015, 08:02 PM
And the valves are misssing lol
Old 24-02-2015, 04:44 PM
jc1989rs
jc1989rs's Avatar
Default Day 2
Not sure how well you can see in the picture but all the levels dropped in the cylinders with number 3 and 4 the worst. Have ordered up new rings and big end bearings and starting to remove the block tomorrow.
The engineer checked the head and the valve guides are all good so have re seated and cleaned up the head all ready.
Old 24-02-2015, 09:52 PM
Just out of interest how did you check your turbo?
The symptoms of smoke on the over run point more towards oil being drawn through the intake IMO?
If it was the rings wouldn't it smoke more under load?
Old 25-02-2015, 04:10 PM
jc1989rs
jc1989rs's Avatar
I checked the turbo hoses, intercooler and inlet manifold there were all clean and free of oil. Then I sent the turbo off to get checked just to be in the safe side!
Old 25-02-2015, 04:18 PM
jc1989rs
jc1989rs's Avatar
Default Day 3
Hey all
Gonna be brief as I'm knackered
The blocks out!
The sumps off, gonna strip down the block tomorrow. Forgot to mention before as you can see from the pictures the exhaust valves have hit all the pistons at some point to.
Here's a few pictures of the day's work.
Old 25-02-2015, 04:25 PM
costina
costina's Avatar
Timed up like a pinto puts marks in the pistons like that usually intake side tho.
If is was me i would bore next size and have new pistons with valve cut outs.
Old 25-02-2015, 05:02 PM
tony66
tony66's Avatar
Default guides
check your valve guides for damage-lots replace the valves but the guides have been damaged also and not changed...great little engines to change-the 4x4 versions are a pain in comparison...
good luck
Old 25-02-2015, 05:39 PM
jc1989rs
jc1989rs's Avatar
Just had a look back through the massive folder of history for the car. Apparently the cambelt broke back in 1991 with only 12000 on the clock and the work was done by ford to repair. The Pistons were taken out and scanned for fractures then to. I don't really fancy having the block bored out of she doesn't need it but will get the Pistons sent away and X-Rayed when I take them out to be on the safe side.
The valve guides have been checked to and are all good, in fact there spot on so I'm guessing they have been changed at some point to.
Old 25-02-2015, 06:14 PM
It didn't take you long to get the rest of the engine out.
Old 25-02-2015, 07:05 PM
jc1989rs
jc1989rs's Avatar
No wasn't to bad, was a day to get the head off and stripped and another day to get the block out. I wasn't rushing though so could be done quicker.
Old 26-02-2015, 05:58 PM
jc1989rs
jc1989rs's Avatar
Default Day 4
Hey all
Stripped the block today and took it down to the engineers and it needs a rebore, the worst was .8mm out on number 3 the rest pretty much as bad.So there gonna sort it out and fit the oversized Pistons.
Have ordered up some new main bearings to as the centre one was starting to wear into the brass.
Old 26-02-2015, 06:56 PM
Guinnless
Guinnless's Avatar
Originally Posted by jc1989rs
Hey all
That's a lot of wear! First oversize is 0.5mm.
Check the crank journals for ovality too especially with wear characteristics like that.
You're clearly doing the right thing though. Hope you are back on the road soon.
Old 28-02-2015, 04:34 PM
jc1989rs
jc1989rs's Avatar
Default Engine block
Yeah it looks like this engine has had a hard life! The crack journals are good, had them checked. The wear is down to end float as the thrust washers were worn.
This engine isn't her original engine either, just checked the block number to the log book and they don't match. God knows how many miles this engine has done!
Ah well she will be good as new once all the work is done. Blocks back Wednesday!
Old 28-02-2015, 05:44 PM
costina
costina's Avatar
Dont forget valve cutouts for future power upgrades. Will cost approx 100 pounds more.
jc1989rs (28-02-2015)
Old 02-03-2015, 07:58 AM
cossynut2
cossynut2's Avatar
I think he has been very lucky that his engine did not self destruct with the valves hitting the pistons!
Old 02-03-2015, 04:50 PM
costina
costina's Avatar
every engine i have taken apart has had valve marks on the inlet side. Which is common due to over revs.
Old 02-03-2015, 05:21 PM
cossynut2
cossynut2's Avatar
My pistons have the valve cut-outs so I have never had a problem, Didnt realise it was a common thing that happens on Cosworth engines.
Old 08-03-2015, 05:00 PM
jc1989rs
jc1989rs's Avatar
Default Blocks back
Hey all
Picked up the block yesterday and started to re build it. Got the crank back in and the new Pistons are on the con rods ready to go in tomorrow. Gonna give it a lick of black paint to once its built.
Looking for everyone's oppinions on breaking in the engine once it's re build. There's a lot of different opinions varying from taking it easy for the first 500miles (under 4000rpm) then oil change. Some say stay under 4000rpm for the first 100 miles, oil change and then keep it under 6000rpm for another 500miles.
Paul_RS (08-03-2015)
Old 08-03-2015, 06:19 PM
tony66
tony66's Avatar
Default breaking in
to break in use mineral oil for first few miles-once you are sure bottom end is quiet give it some boost[try and avoid big revs]-dont be too gentle or bores can glaze-you need to get the rings well aganst the bore
then i would go semi synthetic for say a few hundred miles or so give or take-then once everything has bedded in go fully synthetic..
there are variations on it and different ideas
Old 08-03-2015, 09:56 PM
throttle jockey
throttle jockey's Avatar
Agree new pistons.
Don't mean to be rude or cause any argument,but I've done what your doing and in the end caused a world of pain,also had advice from local engineer telling me to do what your doing and it ended costing more to do again,
but it's the bores that wear more,not that the rings don't mind normally it's both when the bores shine like yours.
I had a engine that was built by castle performance that had done 25+k and I could see the honing clear as day when the head came off.if you look at your picture your bores look shiny,it not ideal,I see you now had the bores honed aswell so new rings and honing is only gonna be a very short term fix as honing is taking material away from bore combined with already the original wear of the bores.new rings won't take up the bore wear
Th yb engines are more specific to certain requirements of tolerances due to the boost pressure etc none of which do I understand either only what I've learned and listened to by nms who have built my motors for me,be a shame to wast your time and money when you have it apart and most tuners unless a new big spec 500bhp car that had a 10-15k freshen up from new built motor won't hone and fit rings as a rule of thumb even the guides would need a change at that level,
From what you say you don't think the engine had a easy life either just thought I'd let you know my experience,your cars looks sweet to good luck with the build.
Old 08-03-2015, 09:59 PM
throttle jockey
Also looking at your block deck I'd get that faced aswell as that can cause more issues again the faces need to be perfect for it to be done right.
Old 08-03-2015, 10:35 PM
costina
costina's Avatar
I would agree the deck needs to be machined.
Best get it done while its apart.
Old 09-03-2015, 04:37 PM
jc1989rs
jc1989rs's Avatar
Default Blocks assembled and painted
Hi all
So finished off the block today and gave it a lick of paint. Was going to put the clutch on and get it back in but they sent me the wrong clutch, so tomorrow!
I had the block and head checked to see if they needed skimming but they didn't so no point.
Pictures of the days work!
Old 09-03-2015, 07:01 PM
costina
costina's Avatar
You have forgot to fit the back plate.
Old 09-03-2015, 08:25 PM
jc1989rs
jc1989rs's Avatar
The back plate slips on over the flywheel, it's cool. Cheers though!
Old 11-03-2015, 09:23 AM
jc1989rs
jc1989rs's Avatar
Default She's on the ramp!
Hey all got her back on the ramp yesterday and the block in. Going to get the head on today and everything else ready for start up tomorrow.
Old 12-03-2015, 06:50 PM
jc1989rs
jc1989rs's Avatar
Default Nearly there!
As you can see from the pictures the heads on and both manifolds! Starting her up tomorrow!
Old 13-03-2015, 12:20 PM
Getting there matey.
Old 13-03-2015, 01:01 PM
The Youth.
The Youth.'s Avatar
getting there but are you sure the head and vlock didn't need skimming, that was an ideal opportunity to skim both and fit a fit and forget wrc head gasket
steve
Old 13-03-2015, 01:09 PM
costina
costina's Avatar
steve
dont waste ya time steve...lol
SmudgerByName
52
28-07-2016 06:14 PM
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
MARKYMARKONE
02-08-2015 09:33 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Sapphire engine tear down & rebuild
