Get your graphs out.
Thinking about changing engine spec later in the year and want to get some ideas on what way to go, current spec is t34 .48, 55 blacks, 4x4 inlet, L8, dyno mapped. I like the power delivery of the T34 so would be looking for somthing with a simlar kick just a little bit bigger one.
So us your graphs and tell us your spec.
Standard engine, borg warner efr 7064, 1000cc injectors (for later, maybe) and a vipec with coil on plug. The Turbo will do 530bhp.
The efr turbos spool up MUCH faster and give more torque and more power.
You will need a 4 inch down pipe and suitable exhaust for that level of power. The inter cooler will need to be up to the job too but you could easily cap the power at 400 for now and add more boost later. My low boost map at 320 bhp still makes a very fast and easy to drive car.
opposite lock (12-01-2015)
I'm definatly interested in this route.I'm kinda stumped with mine at the moment,i dont want to run a bigger turbo,ie t38,as it moves the power up the scale,also not sure on act's as i can't fit in a larger intercooler.
The only problem with the bg turbo for my car is the manifold,its very tight for space.Its a 4x4 manifold,you can't fit a 2wd in.
There isn't too much to change, manifold (essential) maybe a boost pipe, update the injectors and then remap.
Mark
here's my spec
200 block
6 long studs
Std std crank
Cosworth pistons .25
7.9:1 cr
Mahle shells
High pressure oil pump
Big wing sump
Wrc headgasket
Nick waples ported head
Double valve springs
16/14 cams
Vernier pulleys
Hart Inlet
2wd exhaust manifold
T38 billet compressor turbo
83lb Siemens
200 block
6 long studs
Std std crank
7.9:1 cr
Mahle shells
Big wing sump
Wrc headgasket
16/14 cams
Vernier pulleys
Hart Inlet
83lb Siemens
Mark Shead made my manifold as space was tight in the 205 bay
https://passionford.com/forum/restor...ng-gear-4.html
Here is a link to both graphs, low and high. You can see in the thread that Mrk thinks it will do 520 bhp and 535 ft lb with the engine rebuilt.
Happily retired
Mattman, it looks like the down pipe would need to be ovalled or notched around the chassis, just below the lambda, I am sure a 4 inch with a big flat would still flow more than a 3 inch.
Happily retired
All I know is that Mark asked me to upgrade so I did.
Staffi (11-01-2015)
cossie fan (unluckerly)
The one above does seem to make all of its power late in the Rev range, I bet it feels very boosty, is it laggy to drive?
It's on standard 4x4 exhaust manifold and inlet
I was thinking of adding a plenum spacer but I have heard they make it a but mor laggy?
Happily retired
That engine was very controversial at the time. 550 was where it was at & mine struggled to 500bhp really a 490 engine. It was a 450bhp Spec. engine with 42psi up its arse hence the incredible torque. I was the first of the MAD engine to use mega boost.
It was the fastest Sierra of its time proving that Torque is as or more important than Power. 183.3mph, 0-100 8.1 & 11.8 @127mph. My 840 engine is the same Torque not Power & the next one will be the same.
Mark has always said you strap this great big air pump to your engine best to use it.
