T34 water cooling pipes
I am looking a ditching the metal pipe in favour of braided pipe crimped to a banjo.
The problem is that i will have to run this where the metal pipe was routed and it as close between the manifold and turbo.
The pipe i have in mind is a braided fuel pipe so i can jubilee it onto the thrmostat housing ( ie less joins)
this pipe has a max temp rating of 120 deg C......
Whats your thoughts on running this pipe close to the manifold and turbo inlet side.
Regards
Tim
Regards
Tim
Mark RS
12-10-2015 06:01 AM
