whats the symtoms of having the tps wires round the wrong way on 4x4 tps and 2wd loom
Old 20-07-2012, 09:05 PM
neo
neo's Avatar
Default whats the symtoms of having the tps wires round the wrong way on 4x4 tps and 2wd loom
Hi what is the symtoms of using a 2WD loom with 4x4 TPS and L8 ECU but not swopping the pins over ??? ive had a misfire but i didnt know to swop the wires round in the TPS loom plug ...
can it cause a misfire midrange or big flat spot etc....
Old 20-07-2012, 11:23 PM
daz1968
daz1968's Avatar
Not sure about symptoms but you can check wiring with a multimeter to make sure is correct.
Old 20-07-2012, 11:28 PM
darrenb16two
darrenb16two's Avatar
Massive flat spot when mine was wrong! Bit of a low down the revs misfire aswell
Old 21-07-2012, 10:08 AM
martysmartie
martysmartie's Avatar
It will run badly, also the voltage won't be in the correct direction, i.e. 2WD voltage decreases with the throttle increasing, 4x4 increases.
Martin
Old 21-07-2012, 02:58 PM
William MK2 Cosworth
William MK2 Cosworth's Avatar
The ecu probably thinks you are off the pedal when you actually have it flat down, so mine ended up having a nice responce up to the mid way, but nothing all the way after that.
As said always a good idea to check the output of the tps (middle wire) to see if it is correct for your ecu.
Old 21-07-2012, 03:26 PM
chrisa3
chrisa3's Avatar
Overfuelling lower down, cutting out, generally shit to drive till around 1/2 throttle where the signals would be the same which ever way it was wired.
big_Rad
15-09-2017 09:36 AM
FlashRS
14-09-2015 12:36 PM
kosienutter
31
22-08-2015 09:55 AM
muz
16-08-2015 12:57 PM
Roosie
15-08-2015 08:09 PM
Quick Reply: whats the symtoms of having the tps wires round the wrong way on 4x4 tps and 2wd loom
