Abs sensor
Abs sensor
Hi guys
Any one know where I can get front abs sensor for sapphire cosworth 4x4?The garage has contacted Ford but thy no longer make them but have put search out across uk for them
my saph 4x4 needs a round connector i think the escos ones are a square fitting so would be different i actually have a second hand escos one in the garage bought by mistake so may be best to source one from a breakers on here?
The ABS sensors are the same as other ABS models, and MK3 Granadas, FOR 2WD.
I know the 4x4 ABS system is different, but are the sensors not the same?
You would be crazy to buy from Ford, or indeed even new as they are expensive, a second hand option is better, imo.
Martin
Martin
Thats what i been thinking, the prices are bonkers, just concerned bout buying second hand sensor incase it doesnt work. suppose its worth a shot though
The scrap yard up the road from me is full of Granada's, Scorpio's etc - i'm going to check to see which ones match
Mine bust apart so i stripped the metal insert out and cleaned away all the oxidised alloy refitted the insert and built up with plastic weld and held with a zip tie, they have been like that for about 2 weeks now so i'll remove the zip tie and smooth the body and repaint black job done.
Although I am NOT sure on the 4x4 models/Escos (Someone has already stated the latter has different connectors) as I know these have a slightly different ABS system, but the 4x4 sensors may be the same?
Martin
