splutters under load
2wd sierra cosworth,new rebuild.timing done ,injectors working.ticks over at 900rpm.underload it splutters.it has new sensors on it.any advice would be good.the injecters work but are second hand
mmm as i am away i will have to get back but sure msd just gapped them.is there a suggestion on good plugs and gaps.one of the injectors has just been replaced as it was not working.i wonder if the plug needs a clean
ignition leads are new but i am interested that it could be electrical,i am feeding this back to the garage.he just says ecu but it is in the electrical system.to be fair it has new everyrhing inc roter arm dizzy cap but i am onto it .i do have diffrent ecu's to check,what about the screw on the ecu what does this do
depends on what stage of tune you are running and iginition system. Standard coil, coilpack conversion. Mines just at stage 1 (1bar of boost) and im running Escos PP8s gapped at 0.7mm and its sweet. I'm Switching to MSD Stage 3 and will be putting 071c's in it and gapping them slightly closer at around 0.6mm. Im on the standard ignition system.
i have the group a coil n when i get of this i phone will wire it up.i have just ordered new plugs as i believe they fook up easy n don't get going easy .0.6 mm 071 ngk ordered cheep like but will buy some better ones when the system works
nice one on the rev counter as i say i have to relay this all back tmz.i dont have a signal at the moment.i will write all comments down and have a chat tmz.talk to me about what the rev countet does and the problems this shows
Problem sorted ,i am away and the mechanic is a bit of a no it all.
ECU he said.
It was the plugs they were corroded.
Put 2bar sensor on and a new set of plugs.
The gearbox is going back to the reconditioners though as its noisy.
They are going to take it out n fix it on warrenty.
The car passed its mot today.
Yes the car passed its MOT ,a bulb and track rod ends.
Brilliant.Yes the car passed its mot.
ECU he said.
07-10-2015 12:56 PM
wheelwizardrefurbs
22-09-2015 05:45 PM
