2wd saph diff
2wd saph diff
Hi, am i right in thinking that 2wd saph cossie have 7.5' rear diff as standard? What are the differences in diffs as i see ppl mention 7' and 7.5 alot whats the pro's con's etc?
Correct 2WD has 7.5, as did Granada's, lesser models had 7" diffs (Although some late DOHC 2L had 7.5") the 4x4 beam is just the same as a lesser model, the 2WD beam is different so as to accommodate the bigger diff, so you can't simply just change the diff.
In both Cosworth models they naturally are LSD'S.
Martin
Martin
Zee Germans are coming
my advise mate is
if you dont need the money from it keep it as a spair
good parts are hard to come by these days
keep what ever you can you may need it one day
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
