advice on turbo please!
what turbo would you guys recommend to use with this setup?
ive got a universal turbos T38 at the moment, should i sell and maybe get a GT30??
what power/torque should i expect?
200 block
8.7:1
10 long studs
WRC head gasket
Mahle pistons with valve cut outs
ARP bolts
4x4 inlet with spacer (also got 2wd inlet)
83lb blacks
high pressure oil pump
4x4 ported and polished head
26mm inlet and 24mm exhaust
BD14 and BD10 cams
vernier pulleys
isky double valve springs
going in a 2wd
Thanks
200 block
8.7:1
10 long studs
WRC head gasket
ARP bolts
83lb blacks
BD14 and BD10 cams
vernier pulleys
going in a 2wd
Thanks
there's lots to choose from now, turbo's have come along way. years ago it used to be, t34, t38, t4 but there's lots of choice now
most will depend on budget tho.
gt3071r seems a popular choice but the new gtx range seems the latest big thing
you can have a gtx3076 which apparently spools like a gt3071.
who's your tuner, what HP are you aiming for?
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
