Removing ABS
Old 11-09-2011, 02:55 AM
wattie
wattie's Avatar
Default Removing ABS
Been thinking about removing the abs from my 3 door, it never worked properly when it was on the road plus someone has chopped through the sensors at some point for what ever reason , would fitting a non abs master cylinder work on my servo or could I split the brake line with a t peice to feed the front wheels as there's only 2 take offs on the current master and bin the abs or is it just a stupid idea and just replace all the nessesery parts I need for it to work, anyone done it before, it won't be missed if it goes
Old 15-09-2011, 01:45 AM
wattie
wattie's Avatar
I miss tabetha ! No one done this?
Old 15-09-2011, 09:07 AM
martysmartie
martysmartie's Avatar
If you don't want the ABS then you can simply remove it, without touching any of the hardware, there is a diagram on here to do it PROPERLY, i.e. so the warning lights etc don't illuminate.
You can also disconnect one connector, and this too will disable it.
Martin
Old 15-09-2011, 09:39 AM
cozmeister
More boost Igor!
cozmeister's Avatar
Martin
What he said
Disconnecting the level sensor from the fluid reservior is sufficient to disable the actual anti-lock system without disabling the power assistance, and seens as some muppet chopped through the wheel sensors, it's no wonder it didn't work
There's only one Sierra vacuum servo that's remotely capable of powering the standard 4-pot calipers, and if I remember right, it's pretty hard to get hold of. Personally, I prefer having 160 bar of hydraulic pressure to power my brakes instead of a girly little servo. My humble opinion is (as ever) to fix it properly - probably only had a wheel sensor fault in the first place, and they're far easier to get hold of than suitably powerful servos.
Old 15-09-2011, 12:16 PM
martysmartie
Plus as well space needs to be consideration where the YB is concerned as things are pretty tight under there to start with, i.e. I can't see a servo being able to fit between the small gap between the turbo/bulkhead/heat shield.
Martin
Old 16-09-2011, 01:28 AM
wattie
wattie's Avatar
I'll try that, cheers
Old 16-09-2011, 05:59 AM
dojj
Resident Wrestling Legend
dojj's Avatar
You can use the stuff from any sierra which has discs all round such as every dohc sierra so they are very very easy to get hold if and plumb in
You'll just need new brake lines from the m/c to the rest of the car
It's going to easier and cheaper and less hassle overall though to fix your system with a new sensor
Old 16-09-2011, 10:46 AM
cozmeister
More boost Igor!
cozmeister's Avatar
Beg to differ, neither of my DOHC Sierras had discs at the rear
Old 16-09-2011, 01:00 PM
dojj
dojj's Avatar
In which case you will have had either an 89 spec car or a 92 spec gt
Or something not built for the uk Market
Old 16-09-2011, 03:19 PM
mark r
mark r's Avatar
i dont have abs working on my 3dr and i dont have any problems was like that when i bought car
Old 16-09-2011, 05:02 PM
martysmartie
But you will have a working MOT light, unless you have been using a bent tester.
It's very easy to remove ABS, it's a completly different system which merely will take over and modify the braking when required.
Martin
Old 20-09-2011, 04:13 PM
cozmeister
More boost Igor!
cozmeister's Avatar
I have a habit of picking up "special" cars but I don't think either of my twinkies were that "special". If you do a reg-check on K218 THG, it will come back as a '92 LXi...
Old 20-09-2011, 06:21 PM
dojj
dojj's Avatar
it's a 92 spec car so it's probably been a parts bin special friday night jobbie
to clarify, get any dohc sierra from between 90-91 and you will see they've got discs all round and no abs
Old 14-01-2019, 12:16 PM
Victor Brown
Victor Brown's Avatar
Default In case you are interested,
K218THG is on Facebook at the moment about to be broken for parts.
Old 14-01-2019, 03:14 PM
R4N SS
R4N SS's Avatar
my 1991 saph ghia had discs and no abs from factory.
Now running full cossie power and got focus rs discs up front
tankybaby66
06-02-2016 02:24 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: Removing ABS
