fuel economy?
fuel economy?
i heard off a mate something about closed loop or something to do with a 4x4 having a lambda sensor and being a good conversion to a 2wd.
is that true? he'd heard of people geting 5 or 6 mpg extra from it with no ealtime loss in performance.
and more than that up to 10 to 15 miles depending on what stage tune .have a look on motorsport development web site for the chip with closed loop for your car
thanks for that.
L8/P8 here:
http://www.motorsport-developments.c...losedloop.html
i see the P8 is used on quite a few bikes etc but the L8 is more cosworh specific and they say it's standard on escort cosworths but is it a case of - every loom from every cosworth is the same - you just need to unplug the L1/L6 ECUs and plug in an P8/L8? What is the difference between the 2?
i know very little about cosworths but am willing to learn... i want a usable performance car - not one that does10-20 to the gallon as soon as you press the accelerator down!
i have a cosworth with no engine or gearbox and no engine loom but its got a map sensor and a -31 actuator i think. Got a pace intercooler as well (£10 delivered! thank you ebay! ).
L8/P8 here:
its impossible for us to say how much you will gain, or if you will gain at all, because it depends how well the car cruises and idles now,
If it cruises at 9:1 then you can expect some mega fuel savings!
Closed loop will self calibrate the fuelling under certain driving conditions and allow a perfect cruise at lambda 1. its especially important on large injectors, where the ECU can struggle to have enough controlability or break points to map them to fine tolerances, and closed loop can "fill the gaps" so to speak.
Personally i wouldnt own a cossie without it being closed loop controlled. but thats my opinion, and the opinion of pretty much every car manufacturer who has made a car since 1992.
Fuel economy is only one of the reasons to fit closed loop, the plugs will last longer, the engine life will be increased, the oil will stay fresher and last longer,and you are doing your bit for the planet! all benifits of good fuelling.
Nice to hear - i want a quick but reliable cosworth as parts are rare and although relatively easy to fix, incredibly difficult to get hold of the parts!
Especially since it's cheaper for me to insure a tuned cosworth (listing suspension/engine mods!) than a bloody stock 1.4 focus!! Why the hell is that!?
Last Time, Get Off PF FFS
I have not got closed loop Yet lol, but on the way back from Silverstone I got 42 mpg and I wasnt exactly driving economically too, I had my mathmatical genious of a wife calculate it all 3 times and we were both shocked at the mpg the cossie got, cruising about 80/90 with a very very (exhaust scrapping) heavy boot load too. We measured it out of a 1/4 of a tanks worth from top to 3/4 full. Got 150 miles out of 1/4 of a tank. On the way up though I got 165 out of 1/4 of a tank as I was driving more sensibally.
Cossie MPG
TT T38 Power
Wow!! I am amazed at your MPG figures, what Cosworth do you drive, 3 door or Sapphire? What engine specc have you got? I think I have done well to get 25 mpg on a motorway run !! When pressing on hard you can almost see the fuel gauge dropping. Maybe another trip up to MSD to get the closed loop fitted is on the cards.
Drops a LOT when you have fun
Steve
Happily retired
Silly me I thought Cossies were about going fast. Surely if you are checking fuel ecconomy its not the car for you. My Pug 107 will return 50mpg however you drive it. As for trying to get 40mpg from a YB almost dropped my Coffee at that. Its like sleeping with Kylie & not touching the goodies. Come on lads she should be getting a right bashing same with Cossies.
I am very very amazed about these mpg figures !!
My 3 door stage 1 closed loop ,with engine in very good condition ,don't get lower than 13.8l/100 km. ( 20.5 mpg)
This driving very slowly, almost no boost pressure , 95 % of the time !!!
Really , my racing time is long gone.
Even motorway makes no great difference ??
Checking AFR and CO gives very good figures .
When i start using turbo boost i really see the fuel gauge dropping.
I do not understand where all the fuel is going
How you guys get 25 or 28 mpg is a complete mystery to me.
May somebody got tips ?
Grts
Patrick
Thats fine in some cases, but to me there is no need for them to be poor on fuel during some scenarios, as example if your cruising on the motorway, or crawling around in traffic its a little pointless them doing 10mpg when you could be doing 30mpg. Thats like driving around handing out £5 notes from your window.
If your not bothered about how much its costing to run think about where all the extra fuel being used is going and what it is doing as the fuel economy is only part of its advantages.
Cossie MPG
