Rear Arms
They are different in the width of the "eye" mounting point for the damper, it being around 1/2" wider on the 4wd, that and the as mentioned arb location point.
cheers mate!! what am doing is converting a 3dr cosworth to 4x4 so I guess I'll be better off changing the complete rear end.... am I right?
Resident Wrestling Legend
You'll have to changes the whole rear end if you want to go 4x4 as the diff is a different ratio and the shafts are thicker and the stub axles and everything
Just leave it as it is as the hassle to change it all over for a 0.02 difference is ratios won't upset the gearbox
Fudgey
17-09-2015 01:06 PM
Tony W
09-09-2015 12:08 PM
