braking disaster
heffo
braking disaster
fully restored my 3 door cossie .when fitting abs sensors i put vaseline in around sensors to keep out water dirt etc .abs light now comes on after driving for a few mins .is this because of vaseline or what should i use it looks like there was some sort of grease on them when i took them out.anyway i decided to test brakes at around 60 mph when i stood on brake back and front wheels lock up and car almost spun around 360.should back wheels lock up or is bias valve fucked .any replies would be helpfull thanks.
Sounds like a leaky accumulator , turn on ign and listen for brake booster pump starting to pressurize system.should not take longer than @ 30 seconds....you should get certain amount of brake press's before motor starts again.....can't remember the number...
If it comes on after driving its most likley a sensor. If it was on all the time i'd be looking at the other components. If something other than the sensor is faulty, the ABS light will be on from the moment you get to the second ignition position.
Almost certain down to a sensor, it's spot on what you have done putting the vaseline around the sensor, if you diden't they would sieze in the bore, this will in no way effect the operation though.
Check the sensors are all clean and that the ring gear is also clean as said, if there is dirt etc in between the teeth this will cause this.
Martin
Martin
