l6 to l8 conversion what do i change
13-06-2011, 08:19 PM
grayzo
as above what is needed for me to convert from l6 to l8 ecu
thanks
13-06-2011, 08:23 PM
i think you need the 4x4 tps and swap the 2 outer wores around on the connector . pretty sure thats all i did and obviously the ecu swap..
13-06-2011, 08:46 PM
14-06-2011, 12:11 AM
so its that easy...
is it the same for fitting p8 as that would suit him more....
then chris you can run closed loop/ anti lag/ launch control/ air injectors/ piggy back dizzyless ignition the lot.... and its the best for mapping
14-06-2011, 07:26 AM
grayzo
Quote:
Originally Posted by
rsmark86
so its that easy...
fuck me im not that rich yet mark lol
15-06-2011, 01:48 AM
grayzo
best get the overtime in son cossie ownership aint cheap lol, i know this is number 4 lol
15-06-2011, 07:39 AM
You need a PF09 (4x4) TPS and you then have to swap the outer two wires, L8 can do everything mentioned, i.e Anti-lag, Launch control, CL, Air injectors, WS, L6 is also capable of WS if wanting to!
Martin
15-06-2011, 03:58 PM
Fae the Dale
Is there any other benefits from this conversion except those above?
16-06-2011, 01:16 AM
16-06-2011, 06:43 AM
Ive got a PF09 if needed.
16-06-2011, 11:58 AM
grayzo get on the case...
l8 with wasted spark coil pack conversion and t38 set up
16-06-2011, 12:27 PM
I don't think the mapping can be made better, but rather the hardware is better, for example it has double the memory of the L6 (128K opposed to 64K), I am pretty sure it's just a board inside that differentiates the two (Excluding the visual differences, CO screw, wings etc) remove this board and your left with an L6
Martin
Prickly_buzz
07-12-2017 09:52 PM
Cosnada
07-01-2016 05:30 PM
Johnny Knoxville
30-09-2015 07:21 AM
SMILER258
28-09-2015 09:04 AM
marky_g
12-09-2015 04:26 PM
