2nd hand turbo advise
hi folks, what do i need to look out for in buying a second hand turbo? Its of the car now so cant hear it working? Cheers luke
Zee Germans are coming
check the blades are in good nick
and give the shaft a wiggle to make sure there is minimal movment
just a genral look over
nothing else you can do really
Do u mean like chips on the blades? They look clean, and what bit is the shaft? Sorry mate but i know nothing about turbos!
as said, make sure there are no bits missing or bending on the blades
the shaft of the turbo will move up and down a little but not by alot, few mm maybe, but if you can pull the shaft out, even a little, its probably fucked
check for cracks in the exhaust housing
check the wastegate penny for cracks, make sure it shuts nicely against the housing
you will only be able to get hold of the nut on the end and that enough
as said also check for any crackes etc
Cheers mate look well clean apart from a tiny bit on one edge of the blade, it might just be the picture though. The trouble is i dont know how much a tiny little bit on one blade effects the turbo. Apparently the guy can be well trusted though
if the blades are damaged in anyway
if it has any damage what ever or how every big or small then dont bother mate
Matt Baxter
16-09-2015 08:30 PM
borboyous
22-08-2015 11:17 AM
