Rewiring fuel pump
Old 09-06-2008, 04:19 AM
BRAMMER
BRAMMER's Avatar
Default Rewiring fuel pump
One of the issues mentioned at the set-up at MSD was the voltage drop at the pump.
I've been told to cure this i need to run a fresh lead/wire from the back of the fuse box to the pump and a fresh earth is this all that needs doing?? and what thickness is currect for the amount of voltage needed??
Thanks
Old 09-06-2008, 04:31 AM
Use the search function, plenty of info on it.
Old 09-06-2008, 05:28 AM
BRAMMER
BRAMMER's Avatar
Originally Posted by tabetha
If done correctly, and it is hard not to!!, they will be more reliable than ford wiring which can be up to 21 years old so does well anyway!!
If it were me I would run a new live wire/relay from the front to rear for the live, using original wire as trigger for said relay, then earth the pump inside the car somewhere at the rear as there is plenty of areas to get a good earth here, even if it means drilling a hole and using nut and bolt to hold terminal, as it can be easily hidden.
I picked this info out of a thread, this should help.
One thing Tab, is i looked through loads of threads and alot say different types of wire which do i go for as i'll pick some up from work tonight
Cheers pal
Old 09-06-2008, 05:44 AM
I would use either 28/030 or 32/020 thinwall.
Old 09-06-2008, 12:57 PM
BRAMMER
BRAMMER's Avatar
Cheers mate
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Rewiring fuel pump
