amal valve
Old 30-03-2008, 09:07 PM
raziislam
raziislam's Avatar
Default amal valve
just wondering where to put this?? just been rebuilding my saph and not sure where this goes...
also im getting a bleed valve does that mean i can get rid of the amal valve or do i need to keep it?
a pic of a 2wd saph engine bay would be very handy!
thanks
raz
Old 30-03-2008, 09:23 PM
KSA-Cossie
KSA-Cossie's Avatar
Sits on top of the intercooler,keep the amal valve.
Old 30-03-2008, 09:30 PM
raziislam
raziislam's Avatar
where does it screw onto the fmic? ive got a rs500 one and i didnt notice any holes to attach it to..also there are 3 outlets for it...where do i get those from??
Old 30-03-2008, 09:32 PM
KSA-Cossie
KSA-Cossie's Avatar
Ah right in that case you'll need to buy a bracket that bolts to the slam panel m8,as for the pipes type in "amal" into the search facility and it'll show you what pipe goes where m8.
Old 30-03-2008, 09:45 PM
raziislam
raziislam's Avatar
thanks mate! dont want to sound stupid but whats the slam panel!
Old 30-03-2008, 09:50 PM
raziislam
raziislam's Avatar
https://passionford.com/forum/showth...t=fitting+amal
found a link...ok dont want to sound stupid - inlet C where does this attach to the intercooler? similarly ive got a knn filter on mine so what hpns to inlet R?
raz
Old 30-03-2008, 10:36 PM
Char1ie
Char1ie's Avatar
Amal valve is at the front in the middle. Mine is held on with a tie wrap I think. Directly in front of the left hand cam pulley in this pic:
And pictured here. I think mine sits on the intercooler.
Charlie
Old 31-03-2008, 04:35 PM
C = Compressor/turbo
W = Wastegate/actuator
R = Return/air filter, though this one can easily be left off with no problems.
If going stage three or above will most likely need to drill out, or remove RESTRICTOR in end of amal valve pipe.
I just srewed a wood screw into mine and it popped out easy enough.
Old 31-03-2008, 05:05 PM
cossiegreg1
cossiegreg1's Avatar
here's a pic
Old 31-03-2008, 05:16 PM
KSA-Cossie
KSA-Cossie's Avatar
Much clearer now.
Old 31-03-2008, 05:57 PM
cossiegreg1
i know lol
Old 31-03-2008, 08:20 PM
mechanic28
mechanic28's Avatar
dont fit a bleed valve!!!!let the amel valve control the boost!
Old 31-03-2008, 09:51 PM
johnnycos
johnnycos's Avatar
Oops!!!! i have'nt got mine fitted need to think about getting that sorted then?????
Old 31-03-2008, 10:05 PM
mechanic28
mechanic28's Avatar
i would fella specially if your chip is ment to run with one
Old 31-03-2008, 10:13 PM
johnnycos
johnnycos's Avatar
Not sure what my chip should be running with as the car is being run it atm with a stage 1 chip???
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
Quick Reply: amal valve
