AFR problem with stage 3 chip
Old 28-03-2008, 09:06 AM
RSDOHC
RSDOHC's Avatar
Unhappy AFR problem with stage 3 chip
Hi,
I've recieved a stage 3 chip from PTS Motoring , 3 BAR Map , Greens, and RS 500 Cooler.
The boost was recomendet at 22PSI and when I have checked the AFR it was over 14 , so turn the boost back to 1.2 bar (and have now 12,5 AFR).
Please Post your AFR's for more information is it normal to drive with 12.5 AFR , because that wath i hear is under 12 on high RPM, the injectors are brand new the fuel pump is OK , what could be the reason for going lean.
Please Help
Old 28-03-2008, 10:51 AM
jon@work
jon@work's Avatar
have you changed your fuel filter ?
have you checked the voltage at the fuel pump ?
Old 28-03-2008, 12:25 PM
LHD220Turbo
LHD220Turbo's Avatar
Id check the voltage at the fuel pump; to be honest you are better off re-wiring the fuel pump with a direct feed from the battery.
Id also get a 044 pump to be on the safe side
while you are there changes the fuel filter as said by the bloke above
Old 28-03-2008, 12:31 PM
RSDOHC
RSDOHC's Avatar
OK I will fit a gauge to check the fuel pressure , on boost,.
At idle it should be 3.0 bar with the vacum fited , and on boost it must be 3.0 bar + 1.2 bar boost = 4.2 Bar or ?
Old 28-03-2008, 12:37 PM
JamesH
JamesH's Avatar
IMO, anything other than late 11's I'd be worried, I certainly wouldn't be happy with 12s. Those are for ON boost, are you quoting on boost, or off boost fueling?
Old 28-03-2008, 04:39 PM
big mac
big mac's Avatar
check with pts to find out what fuel pressure they run as this varys
Old 28-03-2008, 10:00 PM
KSA-Cossie
KSA-Cossie's Avatar
Should have got an MSD closed loop chip m8,as above though rewire fuel pump,get an 044 pump and new fuel filter,mine runs 11's flat out.
Old 28-03-2008, 10:06 PM
Jasesapphy
Jasesapphy's Avatar
mine runs 10.4-10.8 on WOT
Old 29-03-2008, 07:14 AM
Fuel pressure should normally be around 3 bar idle vac on, around 3.7/3.8 with vac off, but as said check with chip supplier or instruction sheet(with chip) and set at what chip supplier intended though most tend to keep std pressure.
A pump rewire/relay is certainly a good idea, but you do NOT need to use cable big enough to start the QE2 like some think.
JK12
33
26-04-2021 12:09 PM
wheelwizardrefurbs
24-09-2015 08:35 PM
tib2220
14-09-2015 12:33 PM
RSmark84
13-09-2015 01:29 PM
Marino
12-09-2015 11:10 AM
Quick Reply: AFR problem with stage 3 chip
