Just after the sizes for rear anti roll bars. as fitted to the XR4x4, 2wd and 4wd Cossie and the Escort cossie.
I think the 4x4 Saff Cossie is 18mm ?
The Granada Cossie is 18mm as i have one. Also i have a 20.5 mm one is this the biggest there is?
Anyone on here tried the 4x4 version on a 2wd Sapphire? It looks quite a bit stiffer without resorting to the massively stiffer Escort Cosworth one which I think might tax the mounts too much and upset the balance perhaps.
Going to see what effect the adjustable beam ( next month fitting ) has first but then thinking of what to try after that.....
No-one at all running a 4x4 version on the back of a 2wd?
i also run a 4x4 one on my 2wd yes they are stiffer and no nothing else needed same drop links
oh sorry you will need the apropiate bushes for the beam you fit
Ask me in a months time m8, its been off the road since i fitted it having a resto, i did fit new links aswell but they were only 2wd links.
Steve
Ah cheers Steve, I would be interested to hear what you think of it when yours is up and running.
I'm sure I read that the 4x4 one is approx 1.5 times stiffer in roll resistance than the standard 2wd one.
Obviously the Escort Cosworth one is stiffer still but at 3.5 times stiffer than the standard 2wd one and without there being an easy upgrade for the front ARB, my thinking is that there would be too much of a roll disparity between the front and rear axis perhaps. This seems to be borne out by people saying they become a bit too twitchy on the rear in 2wd form when running an Escort Cos rear bar.
I'm also not sure how much extra stress it would put into the mounts with the Escort one compared to the Sapphire 4x4 one.
As i said above i have got a 4x4 one on the rear of my 2wd noticed a hugh improvement a mate of mine with a 4x4 used the ecose one and said the rear became very nervous
Ah cheers Dazzle - somehow missed your post.
Seems to bear out what I was hearing, maybe the Escort Cosworth rear bar is just a bit too much for a non-track car on bumpy, sometimes wet roads.
So no-one has tried the 4x4 rear bar on a Sapphire apart from Steve?
Seems to be a few who've tried the much thicker Escort one .....and then complained it has been a bit too skittish perhaps.
i'm another one, even with really soft suspension and standard bushes, the back end just doens't have enough give in it and it gives very easy tail out action under the slightest of provocation when the roads aren't 100% dry
Cheers Dojj - that echoes what I read from Tony @ Turbosystems
i think the bushes are bonded in mate so it is a complete link , and i think they are about £8 each mate if i remember right.
Hi there anyone who has replaced their rear ARB links recently...
Just got hold of a 4x4 rear bar with the links on. The original coating is all peeling off the ARB so I plan to have it powdercoated and fit all new links and bushes. Quick question though....how did Ford fasten the links to the bar originally? Are they crimped on somehow? ( it's all a bit rusty so I can't see exactly )
