STARTER MOTOR
Old 16-02-2008, 05:15 PM
Barry R
Barry R's Avatar
Default STARTER MOTOR
Is the starter motor on a 3 door cossie the same as any other sierra?
Old 16-02-2008, 05:18 PM
Same as 2wd sapph cossie, easy DIY repair!!
Old 16-02-2008, 05:21 PM
cossie604
cossie604's Avatar
Cheap enough from your local factors on an exchange basis to not even bother with a DIY repair imo....I bought a new one just because I couldnt be arsed to paint the old one to match my tarts handbag of an engine bay
Old 16-02-2008, 05:29 PM
Barry R
Barry R's Avatar
Easy diy i just unscrewed it and it all fell apart now its at the bottom of a skip i need a cheap cheap 1
So the cossie had its own starter then not the same as any other model
Old 16-02-2008, 05:32 PM
There were either 2wd or 4wd cossie starters, that's it.
Old 16-02-2008, 05:34 PM
cossie604
cossie604's Avatar
Are you sure the Granada didnt share the same starter? As mine was availble off the shelf from a local motor factors on a Sunday morning...and yes it was the right one lol
Old 16-02-2008, 05:35 PM
Barry R
Barry R's Avatar
all the motor shops by me are closed 2moro but the scrap yard is open
Old 16-02-2008, 06:17 PM
TurboShed
Cossiemodo
TurboShed's Avatar
LoL, thanks to Tabetha my repair job needed only emery paper and WD40, things don't get cheaper than that
Old 16-02-2008, 06:22 PM
cossie604
cossie604's Avatar
To strip down, replace all old parts with new, and zinc plate the various visual parts that are required to give a as new finish tend to work out a little more expensive than emery paper and wd40 As I said, mine worked fine I just seem to have a spending fetish come once a month, normaly the day after payday before the missus gets hold of it all
Old 16-02-2008, 06:48 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Y.O.U. A.R.E. G.A.Y.
Ok?
Old 16-02-2008, 08:20 PM
cossie604
cossie604's Avatar
You lay awake at night wishing i was what??
Old 16-02-2008, 09:12 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Well, it was the calling card you left in the phone box that started it all!
Old 16-02-2008, 09:36 PM
cossie604
cossie604's Avatar
It offered home starts for cars...not home starts for homo's
Old 17-02-2008, 08:14 AM
The point is you will very likely NOT need to replace all those parts, some just need a gentle cut, maybe even brushes.
The last one I did I did not have any brushes so it is running on old HOTPOINT WASHING MACHINE BRUSHES, cut and shaped to fit now, well over a year now!!
Old 17-02-2008, 10:02 AM
Barry R
Barry R's Avatar
I cant put it back together any way the springs keep pushing the brushes out any ideas
Old 17-02-2008, 08:08 PM
C COS
C COS's Avatar
Are the original Bosch items still available, or any other aftermarket alternators?
I would prefer a new one and not a reconditioned one. Had loads of bad luck with these!!!
Old 17-02-2008, 08:26 PM
TurboShed
Cossiemodo
TurboShed's Avatar
Yes there's a knack to it. You turn it upside down, you have all 4 springs poking out the side, one at a time you raise the housing where the spring is and poke it in, then the next, then the next etc.
It's easy, it took me 2 maybe 3 attempts. One spring is harder than the others due to the position of the cable, do this one first.
Just have a good look at things and you'll see it's do-able.
EDIT: forgot to say, when you turn it upside down, the weight is on the shaft at the bottom, this pushes the housing up inside, making it easier. So be sure that you're balancing the weight on the central shaft, this pushes the assembly up on the inside and makes it all possible.
Somebody needs to take some pics and do a guide, it'll save so many people so much money. I have a starter to do yet, as my spare, I'll take pics when I do it, later this week perhaps.
Old 17-02-2008, 08:42 PM
cossie604
cossie604's Avatar
Dont think so mate...if you find one it'll probably carry a premium. My recon jobby has been perfect and was under £40 exchange.
bobsworth
77
24-03-2016 09:30 PM
A.t.p
23-10-2015 07:54 PM
cossie362
11-10-2015 03:53 PM
Shaunc
Escort Range
23-09-2015 06:00 AM
marky_g
12-09-2015 04:26 PM
Quick Reply: STARTER MOTOR
