***STARTED LOSING WATER 2WD SAPPH*** FOUND THE PROB
Old 31-12-2007, 06:18 PM
m_nettleship
m_nettleship's Avatar
Default ***STARTED LOSING WATER 2WD SAPPH*** FOUND THE PROB
hmmm no obvious leaks? but losing quite alot. Any idea were there nown?????? bottom rad pipe nown 4 rubbing on the sump???
SAny help well appreciated.
Old 31-12-2007, 06:21 PM
rapidcossie
rapidcossie's Avatar
Hard to really tell, but if there are no puddles under the car its prob head gasket.
Dont jump in and rip the head off tho....double and triple check all the hoses first etc
Old 31-12-2007, 06:29 PM
mechanic28
mechanic28's Avatar
can u smell anti-freeze when engine hot etc
Old 31-12-2007, 06:49 PM
m_nettleship
no not really. I have left the car on max level. 2 hour ago, so im gonna check it in the morning to see if it losing it wen stood.
No cream on the oil cap.
and syste dosent seem to be over pressurised.
not running water cooled turbo.
rebuild 6 thou ago.
Old 31-12-2007, 06:54 PM
mechanic28
mechanic28's Avatar
might be worth checking the coolant pipes on the turbo make sure these aint factured,seals leaking etc
Old 31-12-2007, 07:17 PM
m_nettleship
Quote not running water cooled turbo.
leak is alot so u wud think that u would notice it.
Old 31-12-2007, 07:27 PM
Got to be going somewhere!!
I would let it get hot so the fan comes on, then look as you may hear/see it a bit easier.
The normal place for headgaskets on 2wd is above the rearmost core plug turbo side, directly inline with core plug, see if it looks super clean around there.
ps hope it's just a leaky hose, finges crossed, happy new year!!
Old 31-12-2007, 07:44 PM
m_nettleship
Eplain were to look in more detail please mate I will have a look tomoz. Thanks again.
Old 31-12-2007, 07:54 PM
mechanic28
mechanic28's Avatar
opps yer soz fella
Old 31-12-2007, 07:55 PM
mechanic28
mechanic28's Avatar
just look under the exhaust manifold look for coolant stains along the entire length of the engine
Old 31-12-2007, 09:23 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Like yours
Steve.
Old 31-12-2007, 11:44 PM
m_nettleship
do be losing this mutch water, it is losing alot. short period time
Old 01-01-2008, 01:33 AM
mechanic28
mechanic28's Avatar
Like yours
Steve.
Old 01-01-2008, 01:34 AM
mechanic28
mechanic28's Avatar
if its gone here u could lose alot of water have u checked round your water pump
Old 01-01-2008, 08:33 AM
Alvyn
Alvyn's Avatar
if your loosing a considerable amount of coolant and there are no visable leaks then its coming out the rear via exhaust caused by at least a leaking h/g!
this I take you have checked the inside carpet ie near heater matrix
Old 01-01-2008, 11:59 AM
m_nettleship
Well left moter over night and it hasent lost anywater while stood. so must be underpressure 4 it to lose it.
Block had the thickest liners installed. Water pump has resedue oily, but i have just had the turbo return pipe welded up, so thats wats coursed the resedue,, maybe a staem clean and have another look around water pump.
Wen I fire it up,, i will listen 4 missfire or exxcessive steam from zourst,,, hard to tell with condesation aswell..
Mate gonne do a pressure test on the system wednesday.
I will have a good check on the carpets ect, under dash. I think it wud show there wouldent if, heater matricks???
and if it was headgasket, wouldent the heaters blow cold???
Thank 4 the help guys mutch appreciated!
Old 01-01-2008, 02:03 PM
mechanic28
mechanic28's Avatar
heaters can still blow warm with head-gasket gone fella,maybe remove your spark plugs see if they are all the same colour etc
Old 01-01-2008, 02:05 PM
tichy.cosworth
tichy.cosworth's Avatar
check in side the car see if the floor is wet if it is it might be the heater matrix's
Old 01-01-2008, 03:57 PM
m_nettleship
woud it be better taking plugs out wen it has been stud a while, see if wet etc?
Old 01-01-2008, 05:05 PM
mechanic28
mechanic28's Avatar
should not really make anyodds look to se if one or more plugs looks really white compared to the rest
Old 02-01-2008, 10:02 AM
m_nettleship
doin pressure test later today, and take plugs out, thanks 4 info update later.
Old 03-01-2008, 05:53 AM
Alvyn
Alvyn's Avatar
have you found a conclusion after the above?
Old 03-01-2008, 05:53 PM
m_nettleship
Just got bk from me mates, at Gk ford, Pressurd the system up,, and massive Leak, Pipe from Oil cooler to Head, split. Rubber ford item.
Thanks 4 all the help guys.
Old 03-01-2008, 06:37 PM
Alvyn
Alvyn's Avatar
cheap fix then result
Old 03-01-2008, 09:28 PM
m_nettleship
yep I hope mate. Gonna puta normal rubber on i think.
Old 03-01-2008, 11:00 PM
mechanic28
mechanic28's Avatar
good news chap
Old 04-01-2008, 07:02 AM
Good start to the new year, much better than a h/g!!
Old 04-01-2008, 11:23 AM
m_nettleship
wen we pumped the system up, and seen the leak, chopped end of hose and reattched 4 now, simon is on to it at woodford 4 just the one samco.
everyone seen the rr day post in general discussion!!
155lee
27-10-2015 04:55 AM
gcfcos
88
15-09-2015 03:48 PM
dojj
28
11-09-2015 10:00 PM
rsstav
07-09-2015 04:43 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: ***STARTED LOSING WATER 2WD SAPPH*** FOUND THE PROB
