Wheres the diagnostic plug??
Old 30-12-2007, 12:24 PM
skrats
skrats's Avatar
Default Wheres the diagnostic plug??
Can someone please tell me where this plug for diagnostics is on a saff 4x4 ??
Old 30-12-2007, 07:01 PM
YBJ
Thinking Cosworth..
YBJ's Avatar
Its near the main connector of the ECU and looks like this:
Old 30-12-2007, 08:27 PM
Top info there well done.
Old 30-12-2007, 08:28 PM
Is it a flash code system then. I take it the led flashes and there is a chart with the codes on that you follow.
Old 31-12-2007, 11:23 AM
YBJ
Thinking Cosworth..
YBJ's Avatar
Here you go:
Old 31-12-2007, 03:58 PM
Top bloke well done Is there any chance u can pm the codes please.
Old 10-02-2013, 10:18 AM
stussierra
stussierra's Avatar
Default Please help a new owner!
Pardon my ignorance - what does 1+1, 1+2, 1+3 etc mean?
Are these codes relevant to a non-Cosworth DOHC EFI?
Old 10-02-2013, 02:48 PM
JFB Tech
Not entirely sane
JFB Tech's Avatar
1+1 indicates flash, pause, flash
1+2 indicates flash, pause, flash. short pause, flash
1+3 indicates flash, pause, flash. short pause, flash. short pause, flash
etc.
The DOHC codes on the EEC IV are completely different and there are many more of them. The diagnostic socket is by the positive battery terminal. A Gunson Fault Code Reader is ideal for reading these codes and comes with the code list.
Old 10-02-2013, 06:16 PM
stussierra
stussierra's Avatar
Many thanks for the info - I've got one on order!
Old 10-02-2013, 06:25 PM
JFB Tech
Not entirely sane
JFB Tech's Avatar
Forgot to mention, there are two types of plug used on the Sierra, there's a 3 pin and a five pin version. The fault code readers are available with both types of plug, not sure of the codes though, or which one you need.
Old 10-02-2013, 10:22 PM
martysmartie
martysmartie's Avatar
No, you car has Ford EEC management, opposed to the Weber of the Cosworth, this may help http://www.troublecodes.net/Ford/eec-iv.shtml
Martin
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
Brickhouse
14
03-10-2015 07:28 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: Wheres the diagnostic plug??
