how do i turn up th boost
yes lads, can anyone tel me how to turn up th boost i hav jus put on stage 3 stuff board, chip,greens,map sen,rs500 cooler, new t34..48ex wi actuator ...L8 wi 205 block an 4x4 head by th way iv got it as far as 0.9bar, any help would be great thanks, cheers hugh
Just wind a bit more pre load on the actuator mate. Try a full turn at a time, testing full boost under full load, ie 3k on a mild incline in 3rd gearand put your foot down whilst then trying to hold the revs at around 4k using the foot brake and note where the boost peaks on your gauge. Best way to wind up the preload is to unclip teh rod from the gate arm insted of using pliers on the rod with it still in situ..heard of people snagging the actuator diapraghm doing it that way.
Originally Posted by R5FORD
you have to jet them..
ie take the jet out of the valve that goes back to air filter
Originally Posted by Alan s1
As above BUT have you had the fueling turned up to suit the extra boost ect
Offer wise it will run lean and do alot of damage
Alex
Alex
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
